Found Bolens Power Ho And Attachments
3 replies to this topic
#1 trashdad OFFLINE
trashdad
  • 2 Thanks
  • 3 posts
Posted May 11, 2014 - 04:53 PM
I just fouond an old Power Ho with a cultivator and plow attachment in an estate cleanout.  Any suggestions on what I should do to see if it runs.  It does have compression but I didn't want to fuel it up until I found out if there are any precautions I should take.  Thanks for any help, Trashdad
#2 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted May 11, 2014 - 05:20 PM
I have been where you are with that Power Ho. My recommendation would be to drain the oil, and refill before trying to start the engine. Then check to find out if you have spark. On the Briggs & Stratton 8R6 that you should have on a Power Ho, there are points under the flywheel. If it has been sitting, the points may be corroded, but they are easy to replace.
Before trying to move it under power, make sure to thoroughly lubricate the drive chains to the wheels. I failed to do that on one of mine and a seized link caused one drive chain to self destruct.
Check the manuals section for more information on the Power Ho's. You can download up to three manuals per day, more per day if you become a site supporter.
  • boyscout862, Nato77, superaben and 1 other said thanks
#3 boyscout862 ONLINE
  • 13,449 Thanks
  • 9,394 posts
Posted May 11, 2014 - 05:41 PM
Welcome to GTT. Relax and enjoy the site. Good Luck, Rick
  • trashdad said thank you
#4 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted May 11, 2014 - 08:57 PM
Welcome to GTtalk!  Like LPBolens said drain the oil and refill, but also make sure you have oil in the gearbox on the engine.  You should post some pics of it. We always like pics!
  • LPBolens and trashdad have said thanks
