New Guy From Missouri.
33 replies to this topic
#31 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted June 04, 2014 - 10:38 AM
The clutch requires a 1" DIA shaft about 2 3/4" long to use the BH clutch.
#32 olcowhand OFFLINE
  • 43,177 Thanks
  • 32,012 posts
Posted June 04, 2014 - 11:37 AM
Oh I see says the blind legless man..............thanks for the heads up. The bh engine has the splines on it for the clutch plate correct???
No, the crank isn't tapered, just a standard keyed, BUT, the end of the crank must be bored & a pilot bushing installed for the clutch shaft to ride in. This clutch shaft is what has the splines.  Plus, if you wanted to have pto to run a deck, these engines have a special crank that extends past the flywheel for the pto clutch to mount.
  • sacsr said thank you
#33 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted June 04, 2014 - 08:23 PM
Like I said, Daniel always comes through when you need him! :-)
#34 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted June 05, 2014 - 12:07 AM
Thanks Daniel. I didnt do the trade but I did get a free 275 gal steel caged watering tank to turn into a electrolis tank. I still need to make some room in the garage for the bh but I want it in there for sure.
