New Guy From Missouri.
33 replies to this topic
#1 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted May 11, 2014 - 02:33 AM
Hi all I just found this site a few weeks back. I know I havent posted anything yet but just wanted to say hi and introduce my self. They call me stubbysteve cause I dont have any legs. I lost them in 2005 when a ford ranger fell on me and I was pinned for over 8 hrs.
Any way I picked up a D4-10 just a few days ago. It has the WISCONSIN engine in it. The rear wheels turn when you pull in and makes the engine turn as well. the tranny is stuck in the lowest/ farthest down gear. I believe that may be reverse. I say that cause I cant tell what is suposed to be what on the tranny/shifter plate.
I dont know if the rearend is messed up or if the clutch inside the bell housing is messed up. I would think I could still put it in neutral even if the clutch was messed up. So if anyone has any idea let me know please.
Also will be putting up pics as soon as I can take them. thanks.
  • Gtractor, LPBolens, sacsr and 3 others have said thanks
#2 MH81 OFFLINE
Posted May 11, 2014 - 05:15 AM
Hey Steve, :welcome: to GTTalk
There are lots of BH nuts on here, and at least a few of them have been inside those trannys.
Hopefully one of them comes along and can answer your Question.
#3 TomLGT195 OFFLINE
TomLGT195
  • 3,826 Thanks
  • 2,813 posts
Posted May 11, 2014 - 05:18 AM
Welcome aboard Steve. Sorry to hear about the injury!
I'm not much of a bush hog guy, but someone will be along soon.
Enjoy the site, there are a great bunch of guys here. Good luck with your tractor. What are your plans for it? Yes the pics when you get a chance will be very helpful. Tom
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 11, 2014 - 05:38 AM
Welcome Steve. The BH tractors have really been gaining traction lately as collectors items. There are some very knowledgable folks on here who should be able to help sort out those transmission problems.
#5 grnspot110 ONLINE
grnspot110
  • 4,150 Thanks
  • 2,643 posts
Posted May 11, 2014 - 06:28 AM
:welcometogttalk:
From Trenton!  ~~  Lowell
#6 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted May 11, 2014 - 06:49 AM
Welcome to the forum Steve! Glad to add another owner to the Bush Hog owners club! First thing I would do is pull the shifter off the top of the transaxle and inspect the cluster gear- it should move up and down the shaft.image.jpg this is what the cluster gear looks like. You can see a damaged one and then a good one in this picture. The other common problem is a busted ring gear. I would look at these two areas first. image.jpg
We will help you figure it out. Pictures always help, so post some when you can.
  • DH1, Gtractor, LPBolens and 2 others have said thanks
#7 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted May 11, 2014 - 07:19 AM
Welcome to the gang Steve!
#8 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,315 Thanks
  • 4,949 posts
Posted May 11, 2014 - 07:33 AM
Welcome Steve!  :wave:
Hope the tranny problem is something simple.
#9 jd.rasentrac ONLINE
jd.rasentrac
  • 4,770 Thanks
  • 4,262 posts
Posted May 11, 2014 - 07:34 AM
Welcome Steve  :welcometogttalk:     :smiley-flag008:
#10 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted May 11, 2014 - 07:40 AM
Welcome to GTtalk Steve, it's great to have you here.
#11 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted May 11, 2014 - 08:39 AM
Welcome Steve!  If the gear shift lever is all the way down, then it's in first gear.  Reverse is all the way up, shifter closest to the seat.
If the shift lever is stuck & won't move, you'll likely find a lot of rust which has the shift fork frozen to the pin it rides on, or the sliding cluster gear is rusted to the shaft, preventing it's sliding.  Just pull the top shift cover off and you'll likely see your problems right off.  Post up some pics asap!
  Sorry to hear of your accident, but sounds like you have a good perspective on life.  Legs aren't required to be a member, heck, some of us have no brains, but they still let us in here!
  • sacsr and HDWildBill have said thanks
#12 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted May 11, 2014 - 10:51 AM
thanks guys. Of course its mothers day today so I cant take pics today. I will try to get some maybe tomorrow. thanks again guys.
  • olcowhand said thank you
#13 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 11, 2014 - 02:17 PM
Welcome to GTtalk Steve. Between SACSR and OCH you are in some pretty good hands. Best of luck getting it fixed.
#14 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted May 11, 2014 - 10:34 PM
I am looking through the manuals to see if I can find what might be stuck. Sacsr thanks for the pics so I can see what it is and how it is set up in the rearend.
#15 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted May 12, 2014 - 08:13 PM
Does the shifter move up and down? Like Daniel , if it does not, I would check to see that the yoke that is over the cluster gear is not stuck (rusted). It tends to be a little hard to move by hand but it should slide back and forth on the shaft.
