Walbro Carb Problem
8 replies to this topic
#1 Gabriel OFFLINE
Gabriel
  • 1,446 Thanks
  • 1,859 posts
Posted May 10, 2014 - 10:05 PM
I rebuilt a Walbro carburetor that's on a Poulan Pro BVM200 blower/vac. It is a 2-cycle engine. I can't seem to get the carburetor to supply fuel to the engine. I can get fuel in the primer bulb, and other areas, as shown by the arrows in this diagram. Should I be able to see some fuel come out somewhere when I push the primer bulb?
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 10, 2014 - 10:20 PM
The fuel should come out the return line to the tank when you prime it.
Is the diaphragm and gasket on in the right order?  Is the needle metering lever adjusted right?
Ben W.
  • Gabriel said thank you
#3 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted May 11, 2014 - 07:32 AM
There is a cross-over passage in the middle section that moves fuel from the fuel pump side to the metering side.  There is also an impulse passage from the engine to the carb to power the fuel pump.  Are those blocked?
http://wem.walbro.co...rviceManual.pdf
Edited by New.Canadian.DB.Owner, May 11, 2014 - 07:33 AM.
#4 Gabriel OFFLINE
Gabriel
  • 1,446 Thanks
  • 1,859 posts
Posted May 12, 2014 - 09:43 AM
Ben W.
I can see fuel move in the return line. I should probably check those things a little closer.
  • superaben said thank you
#5 Gabriel OFFLINE
Gabriel
  • 1,446 Thanks
  • 1,859 posts
Posted May 12, 2014 - 09:44 AM
I suppose they could be blocked.
#6 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted May 13, 2014 - 07:55 PM
blow those passages out with your air gun   it should help.
#7 Gabriel OFFLINE
Gabriel
  • 1,446 Thanks
  • 1,859 posts
Posted May 13, 2014 - 08:33 PM
Thanks. I took the whole carb apart and cleaned it again, then we carefully checked all the passages, then I blew all of the passages out. I sprayed some carb cleaner in the engine (before I took the carb back off), and it started on the first pull. I'm trying to check everything over carefully, so to make sure I'm not missing something obvious. I will keep you all updated as I move along with finding out what's wrong with the carb.
#8 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted May 14, 2014 - 08:14 PM
thank for the up date
#9 Gabriel OFFLINE
Gabriel
  • 1,446 Thanks
  • 1,859 posts
Posted May 14, 2014 - 09:46 PM
I got it running!!! I wonder what was wrong??????? Maybe something was stuck, and I dislodged it when I cleaned it again and blew all the passages out.
