Kohler Command Single Cylinder
7 replies to this topic
#1 cadet104 OFFLINE
cadet104
  • 3 posts
Posted May 10, 2014 - 09:00 PM
want to install  a kohler command  ohv 13 hp engine from a cub 2130 in a cub cadet 104 wiith creeper gear any pros or cons ???
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 10, 2014 - 09:21 PM
Welcome to the forum.  Why do you want to get rid of the old K-series?  Is it toast?
Ben W.
  • cadet104 said thank you
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,049 Thanks
  • 2,900 posts
Posted May 11, 2014 - 05:22 AM
Welcome aboard! Pics ?
I agree with Ben. What's the reason for replacement? Tom
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 11, 2014 - 05:43 AM
Have you measured the new engine to see if it will fit. The K series had a low crank height in many configurations due to the oil pan extending below the mounting flange. That's pretty much unheard of in newer engines and can cause problems. I guess my answer would be that if you have to cut up the tractor frame or metal to fit it in there then it's not worth it.
#5 cadet104 OFFLINE
cadet104
  • 3 posts
Posted May 11, 2014 - 07:16 AM
actually the tractor i have has no engine,  haven't really measured things up either but was just looking to do something differ i haven't seen yet.  thought it would be cool.
#6 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted May 11, 2014 - 10:21 AM
I would try and stick with the older kohler k series I really don't see an advantage with these ohv engines. Ive been around them I just don't feel they have the same power as the older motors. Look around to see if you could find one first.
#7 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
I'd set it in and see. If you have to cut the frame no big deal. I mean it's only a cub lol I'd be more concerned with the classes a 13hp would have to run against16hp one's here.  But a 12.5hp runs in the 12hp class (Same engine)
#8 cadet104 OFFLINE
cadet104
  • 3 posts
Posted May 13, 2014 - 08:18 PM
I think it's worth a try, what's the worst that can happen it blows up lol
