Vintage Wheelhorse Tractor And Cart - $300 (Foster) Ri
8 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted May 10, 2014 - 03:02 PM
http://providence.cr...4464046814.html
I just feel bad for this GT, looks like a 6 y/o got ahold of a rattle can.
  • Gtractor and hamman have said thanks
  • 14,811 Thanks
  • 15,499 posts
Posted May 10, 2014 - 04:00 PM
That's a good deal, the cart is worth 100.00 to 150.00 by it's self and the tractor is either a 655, 855, 656, 856, 657 or a 857. that's the only 3 years WH made that model with the Electric start Kohler and the drive belt guard had an inset for the model number.
#3 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted May 10, 2014 - 04:20 PM
That looks like the one I have. But mine doesn't have the indent on the belt guard. 8hp Kohler, electric start, and 3 speed. Mine was painted an ugly dark green with ugly yellow wheels when I got it. Nothing to ID the model.
Edited by pharmer, May 10, 2014 - 04:21 PM.
  • 14,811 Thanks
  • 15,499 posts
Posted May 10, 2014 - 04:30 PM
You don't have an ID tag on the dash tower just below the actual dash? Can you post a photo of it?
  • pharmer said thank you
#5 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,327 Thanks
  • 4,953 posts
Posted May 10, 2014 - 04:53 PM
Maybe its a "red line" Hot Wheels?  :(
#6 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted May 10, 2014 - 05:11 PM
  • 14,811 Thanks
  • 15,499 posts
Posted May 10, 2014 - 05:20 PM
Yours appear to have a 3 spoke steering wheel and if it's the original then yours is a 1986 or 69 Commando 8. Wheel Horse use a 2 spoke wheel thru 1967.
Edit, It's got to be a 1968 Commando 8 because WH started using full running boards in 1969.
  • LilysDad said thank you
#8 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted May 11, 2014 - 03:29 PM
I believe this steering wheel is from a John Deere. Inside the cap is JD green.
I will assume it is a1968 Commando 8 from the belt cover and lack of running boards.
At least whoever put this steering wheel on was smart enough to save the Horse and get rid of the Deere.
#9 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,499 posts
Posted May 11, 2014 - 03:47 PM
The cap may be from a JD, but that wheel was used by WH for and couple years and it's the same as the JD wheel JD used at that time.
