I have a '93 GT6000 917.250051 and need to know where the tie rod would attach to the electric actuator bar. Any help would be appreciated. I am going to fabricate my own sleeve hitch.
Sleeve Hitch Electric Actuator Attachment Point Question
#1
OFFLINE
Posted May 10, 2014 - 01:02 AM
#2
OFFLINE
Posted May 10, 2014 - 06:21 AM
Welcome to GTTalk ! There are a lot of Craftsman members here and sure they will be able to help you out .
- blackbird13 said thank you
#3
OFFLINE
Posted May 10, 2014 - 06:34 AM
124371x
In the parts manual for your tractor (http://www.craftsman.../917.250051.pdf) it shows that number. HOWEVER, if you research that number, it says "For tractors with transmission pulley on top" or some derivation of that.
I am assuming it will work with either, or the Parts manual has a typo... Lets hope it will work for either... You have the unit there and can compare these manuals to it to see if the 124371x looks like the right one.
If that is the case, Here is the installation manual for it.
http://www.managemyl...NM/L0105017.pdf
Good luck and
- tractorgarden, Sawdust and blackbird13 have said thanks
#4
ONLINE
Posted May 10, 2014 - 06:51 AM
After looking at your info, Alan, that looks similar to the electric lift on my Craftsman III (917.254420). I need to look into that setup more. It did have the P220 Onan in it.
#5
OFFLINE
Posted May 10, 2014 - 09:38 AM
Thanks so much. Even though the actuator doesn't attach exactly the same on my tractor, the attachment point is what I needed. Looks like I have to remove a nut, bolt and some washers and replace with a pin and clip. By the way, the stack on the one pic was just me playing around with building some mufflers. I tried making the original muffler with automotive type baffles, but the back pressure was a little higher and caused too much crankcase pressure. I have since built another more to original design.
- MH81 and Sawdust have said thanks
Also tagged with one or more of these keywords: sleeve hitch, electric lift actuator
Wanted
Trash and Treasures →
For Sale / Trade / Wanted →
Attachments →
rock shaft, sleeve hitch or 3point hitchStarted by kkmac , Jul 27, 2017 ![]() |
Barn →
Garden Tractor Implement Forum →
Sleeve Hitch Plow IdentificationStarted by Mark 149 J. , Mar 21, 2017 ![]() |
Barn →
Garden Tractor Forum →
Brinly box scraper search.Started by AA Hayes , Apr 21, 2016 ![]() |
Barn →
Lawn & Garden Tractors by Make →
Bolens Tractor Forum →
Building a Sleeve hitch for the Bolens 800Started by steamer936 , Feb 29, 2016 ![]() |
Barn →
Rear Hitch Education Please?Started by Paulgo , May 17, 2015 ![]() |
