Jd 445 Aws?
445 aws
3 replies to this topic
#1 DKForge OFFLINE
DKForge
  • 1 posts
Posted May 08, 2014 - 07:33 PM
Sorry if this is a really stupid question but I have a 445 I bought used and I need to replace the rear rims and tires. How do I know if my 445 is an AWS or not? It appears they use different rims based on AWS.
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 08, 2014 - 07:41 PM
Welcome to GTTalk. If it's an AWS it is pretty obvious. When you turn the steering wheel you'll see the back wheels move as well as the front. I can't recall if those had a special decal that indicated they were AWS. I believe the AWS used narrower wheels on the back to give it the clearance for the rear wheel movement.
#3 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 08, 2014 - 07:42 PM
Welcome to GTtalk.  I can't really answer your question on the 445 but I'm sure someone who can will be along shortly.  Just wanted to welcome you to our site.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,982 Thanks
  • 10,008 posts
Posted May 08, 2014 - 08:44 PM
It will have a 'All Wheel Steering' decal on the fenders above the tires. The tire size will be 23x10.5x12 on an aws, 26x12x12 on a 2ws unit.
If you need to ask if it's AWS, then it's not or you've never used it.
