Gravely 20G Hydraulic Filter - Help!
No replies to this topic
#1 Nashcub OFFLINE
Nashcub
  • 96 Thanks
  • 48 posts
Posted May 08, 2014 - 08:40 AM
Hey, All!
I'm still not having any luck on kicking my garden tractor habit!
Picked up a Gravely 20G the other day and got it back in to good running condition. I flushed the trans once with new fluid and I need to do it again. However, this time I need to install a new hydraulic filter (the big one under the dash).
I printed out the Ops manual, but it is lacking on part numbers and detailed spec info. I would really like to get the correct replacement filter for the hydraulic system. Any Gravely guys out there that could help with this? It does not have to be an OEM Gravely filter, I think a cross referenced filter would be fine.
WHile I'm at it... I am also having trouble re-attaching the 60' deck. Not sure how the hydraulic lift attaches to the deck? Beginning to wonder if all the parts are there to do so. Should there be a spring on the brake lever lock?
Any help would be greatly appreciated!
Gravely 20G Professional
