John Deere 445 Rebuild Has Weak Power
john deere 445
7 replies to this topic
#1 IbleedJDgreen OFFLINE
IbleedJDgreen
  • 1 Thanks
  • 1 posts
Posted May 08, 2014 - 01:31 AM
i rebuilt  my 445 22 hp gas moto this winter/replaced cam gear, now i have 210 compression on both cylinders and no misses. but i have no power when i mow. anyone have any sugestions.  also ran valves again. 20 degres difference between head temp and exhaust temps.. put new coil  on right side... last year... also hot in take with carb cleaner and no leaks....  hydo temp is 150 mowing so i dont think its the problem.
  • superspeedex said thank you
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted May 08, 2014 - 05:24 AM
Is it reving up the whole way?
  • FilledTires said thank you
#3 Alc OFFLINE
  • 6,886 Thanks
  • 7,461 posts
Posted May 08, 2014 - 05:35 AM
Could the governor or linkage not working correctly  ?  I always thought my PK was down on power because it's only12hp and old , turns out the governor wasn't set right and wouldn't open all the way under load , I bet I used it for 5 years before I found that out lol
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 08, 2014 - 05:37 AM
 Welcome to GTTalk. That engine is fuel injected if I remember correctly. Could it be something in the EFI that's not setup correctly. Do you have the service manual for the motor or for the tractor?
#5 Alc OFFLINE
  • 6,886 Thanks
  • 7,461 posts
Posted May 08, 2014 - 05:46 AM
If it's FI my pervious post wouldn't be any help .   I've never worked on a small engine FI system I would guess most controls/sensors  are electronic . If I was working on a car I would start with the fuel system , filter/ pressure  maybe the same on this ?
#6 boyscout862 OFFLINE
  • 12,859 Thanks
  • 9,173 posts
Posted May 08, 2014 - 08:51 AM
Welcome to GTT. Relax and enjoy the site. Good Luck, Rick
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 08, 2014 - 09:23 AM
Welcome to GTtalk.  When you say no power, does the engine bog down or the blades just don't  cut?  How does it run with the deck shut down?
#8 propane1 ONLINE
propane1
  • 8,724 Thanks
  • 4,131 posts
Posted May 08, 2014 - 03:30 PM
Late timing ??   Noel
