Wanted
Wanted : New Or Used Set Of Blades 1725522 54"
22 replies to this topic
#16 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted May 08, 2014 - 07:01 AM
I did a quick search and found that part number on this web site:  http://members.tripo...lens/blades.htm .It lists a three blade set for $60 a set.  Don't know if their info is correct though.
That guy is out of business.....
  • GTTinkerer said thank you
#17 bprzyw OFFLINE
bprzyw
  • 120 Thanks
  • 180 posts
Posted May 09, 2014 - 11:35 AM
I have tried to contact that there guy/website/phone/email several times, and got no where.
#18 DennyIN ONLINE
DennyIN
  • 330 Thanks
  • 204 posts
Posted May 12, 2014 - 10:47 AM
Is a snapper 1-9644 or 1-9711 close to a working fit, looks like no outer holes.
#19 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted May 12, 2014 - 01:09 PM
Many options without the holes but that's not going to help any since its hardened steel.......
#20 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted May 16, 2014 - 07:16 AM
Even though it is hardened steel a decent machine shop should be able to drill the outer 3/8" holes with a carbide bit or on an end mill.  May be a little expensive but it may be the only option.
Are the blades flat or formed? or would flat blades work?  Back when I worked on golf courses there was a company in the south that made custom blades for our $60,000 rough mowers that were extremely wear resistant but they only made flat blades.
#21 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted May 16, 2014 - 07:20 AM
These had the curved lips on the ends.
I'm looking at a few possibilities right now but dont really have the deck or an OEM set to compare them to.....
#22 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,357 posts
Posted May 16, 2014 - 11:13 AM
Oregon part number 90-143 shows under 19 inch blades but the actual length states in the spec sheet at 18 3/4 inches .3/8 center hole.I am not sure on the way the outside measurement  is being measured.
I searched the oregon web site and found this.
Edited by drbish, May 16, 2014 - 11:16 AM.
#23 bprzyw OFFLINE
bprzyw
  • 120 Thanks
  • 180 posts
Posted May 23, 2014 - 09:34 AM
Also looked at that pn# from Oregon, not available. Got a set from Bob (BHTS). Still looking for a spare set though, no rush..........
Also tagged with one or more of these keywords: Wanted
