Wanted
Wanted : New Or Used Set Of Blades 1725522 54"
22 replies to this topic
#1 bprzyw OFFLINE
bprzyw
  • 120 Thanks
  • 180 posts
Posted May 07, 2014 - 06:43 AM
Looking for a new or used set of blades for a 18070-02 series 54" deck. can be used, deck came with none. As long as I can get them sharpened, it would be ok. Thanks
#2 KennyP ONLINE
  • 34,189 Thanks
  • 43,310 posts
Posted May 07, 2014 - 06:53 AM
What brand is this?
#3 Bolens 1000 OFFLINE
  • 14,219 Thanks
  • 17,846 posts
Posted May 07, 2014 - 07:03 AM
They are Bolens but have been NLA for quite some time.
If anyone needs about 5,000 of them we can get them reproduced :D
#4 KennyP ONLINE
  • 34,189 Thanks
  • 43,310 posts
Posted May 07, 2014 - 07:10 AM
I can't help there!
#5 bprzyw OFFLINE
bprzyw
  • 120 Thanks
  • 180 posts
Posted May 07, 2014 - 09:31 AM
I do not know even what to say. There has to be a used set rusting away somewhere. :watch_over_fence:
#6 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 8,302 Thanks
  • 4,566 posts
Posted May 07, 2014 - 12:54 PM
Doesn't Stens have any that will work? My goodness they have pages and pages of blades in their catalog.
#7 bhts OFFLINE
bhts
  • 1,452 Thanks
  • 2,149 posts
Posted May 07, 2014 - 03:51 PM
Sent you a pm.
#8 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted May 07, 2014 - 08:48 PM
I agree with you.
I bet if we take measurements of the blade and center hole plus the width, we could match something up between Oregon, Stens, and Rotary.
Ben W.
#9 Bolens 1000 OFFLINE
  • 14,219 Thanks
  • 17,846 posts
Posted May 07, 2014 - 09:24 PM
I agree with you.
Ben W.
Already Tried every manufacture.......
#10 farmerall OFFLINE
farmerall
  • 2,191 Thanks
  • 1,471 posts
Posted May 07, 2014 - 09:35 PM
Are there any that are a close match? If there are it might be possible to modify the blade or deck slightly so they would work together.
#11 Bolens 1000 OFFLINE
  • 14,219 Thanks
  • 17,846 posts
Posted May 07, 2014 - 09:37 PM
You could do that but it would require some hacking....... :(
#12 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted May 07, 2014 - 09:50 PM
Why should I really be surprised.  Gilson blades are the same way.  I tried Farmerall's ideas once when I got desperate and I did make a Gilson blade.  I ground one down and made it work.  But it was a real pain in the tail.
Ben W.
#13 MH81 ONLINE
  • 29,899 Thanks
  • 29,727 posts
Posted May 07, 2014 - 09:52 PM
Does anyone have the dimensions, just in case there's a set hanging on a nail somewhere?
#14 bprzyw OFFLINE
bprzyw
  • 120 Thanks
  • 180 posts
Posted May 08, 2014 - 06:24 AM
Thanks guys. I have been looking, but not found any that would, at least be an easy hack. Here are the specs per Bolens 1000:
Length: 18-3/4"
Center Hole: 3/8"
Outer Hole: 3/8"
Outer Hole Center to Center: 2-3/4"
Requires: (3) for 54" cut
You would think something would be close, but NO!!
Thanks.
#15 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted May 08, 2014 - 06:54 AM
I did a quick search and found that part number on this web site:  http://members.tripo...lens/blades.htm .It lists a three blade set for $60 a set.  Don't know if their info is correct though.
Also tagged with one or more of these keywords: Wanted
