I have an optional hydro lift pump and cylinder. I want to rebuild the cylinder before I put everything back together.
I have the inlet elbows removed but I am not sure how to remove the piston and rod. Everything I see says it should be easy. How much force should it take? or is this unit welded and not rebuild able.
