Will A Nova 2 Electronic Ignition Module Work On An Allis B-212?
4 replies to this topic
#1 VintageIronCollector ONLINE
    Immersed in Tractors
  • 1,279 Thanks
  • 1,780 posts
Posted May 05, 2014 - 06:15 PM
As the title states will it work? The engine #s are 300421-0127-01-7002091. I might use this if it will work as it will be a lot cheaper.
http://www.ebay.com/...=p2054897.l4275
#2 boyscout862 ONLINE
  • 10,020 Thanks
  • 7,662 posts
Posted May 05, 2014 - 06:28 PM
I want to try one on  my Big Ten. Good Luck, Rick
  • VintageIronCollector said thank you
#3 farmerall ONLINE
farmerall
  • 2,162 Thanks
  • 1,452 posts
Posted May 05, 2014 - 07:13 PM
Yes it will work but I'm not sure what needs to be changed to make it work properly. I know other people have used them on the Allis/Simplicity tractors before.
#4 superaben OFFLINE
superaben
  • 7,664 Thanks
  • 5,677 posts
Posted May 05, 2014 - 08:05 PM
Yes it will work, and yes I can sell you one.  :D
To install them, all you do is cut the wire running from the breakers/condenser to the coil and then tie in the Nova II module on that wire.  It works great.
That gives you breakerless and condenserless ignition.
Ben W.
  • MH81 and VintageIronCollector have said thanks
#5 Sawdust OFFLINE
Sawdust
  • 4,569 Thanks
  • 2,849 posts
Posted May 05, 2014 - 11:16 PM
Here is what I done on my MTD 990. Go to pages 60-63 then go to page 70. It works great. Ben also has the parts if you want to stay original.
 http://gardentractor...-mtd-990/page-4
