Need Help With D160
5 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted May 04, 2014 - 10:01 PM
hi all, got my first wheel horse d series today, a d160, it needs some loving though, i will post pics tomorrow, heres the problem, the hyd relief valve, where is it so i can safely push this tractor? is it above the brake pedel in the larger hole ? this has a shaft with a screwdriver slot in it, is that it? if so i need more help as it will not budge, sprayed some penetrating oil on it, hopefully it will move tomorrow or am i looking at the wrong spot, what else can i do? thanks john
  • 14,811 Thanks
  • 15,500 posts
Posted May 04, 2014 - 10:16 PM
John, It's on the side of the tunnel cover right as you are describing. It does turn with a big slotted screw driver. If I remember right, you only turn it 1/4 turn.
  • JDBrian, boyscout862 and farmer john have said thanks
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 05, 2014 - 04:10 AM
It always amazes me that there is someone here who knows all the details of just about any model. Congrats on the new D160!
  • boyscout862 and farmer john have said thanks
#4 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted May 05, 2014 - 05:38 AM
I have put the screw driver in there and given it a couple of good hits with a hammer to help lossen up the threads before.
  • farmer john said thank you
#5 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted May 05, 2014 - 07:45 AM
augghhhhh!!!! its not moving. tab on screwdriver slot broke off, now what? a little heat? more penetrating oil ? or bang my head repeatedly on it?
#6 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted May 05, 2014 - 05:26 PM
Its been a while, I think you can take off the side plate pretty easy. That will give you access to the valve, you should then be able to put a pair of vice grips on it. I wouldnt heat it up yet.
Ps. DOnt worry if you bugger up the screwdriver end, I got a spare if you need it.
Edited by coldone, May 05, 2014 - 07:40 PM.
