Uncle's B110 Not Starting Need Help
41 replies to this topic
#31 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted January 28, 2011 - 09:35 PM
So much for the rebuild job huh? LOL, what did you find out about the Head Gasket Leak?
#32 olcowhand OFFLINE
  • 38,833 Thanks
  • 30,707 posts
Posted January 28, 2011 - 10:02 PM
Being it was (so called) rebuilt, I didn't consider the starter/gen itself. But was a bad rebuild. Glad you found someone that truly knows how to fix them.
#33 caseguy OFFLINE
  • 1,625 Thanks
Posted January 28, 2011 - 10:13 PM
I'm glad that you got it all figured out! Congrats! Like MH81, I'm wondering what became of the head gasket leak?
#34 Nascar3244888 OFFLINE
Nascar3244888
  • 165 Thanks
  • 593 posts
Posted January 29, 2011 - 08:11 AM
My uncle was really mad about the starter gen. They wanted to charge him 200 for the rebuild.....by the way this is the same guy that did it before......he told him it should have lasted much longer than what it did....he doesnt even use it all that much just some mowing in the summer so they get done faster because my aunt uses the other tractor and he uses it to plow in the winter when the snowblower isnt needed. So they gave it to him for the price of parts....which they should!!!! I replaced the fuel line and fuel filter while I was at it....as far as the head gasket is was starting to separate a little bit, just like my bolens 1050 was but not quite as bad, so thats all fixed now and it runs great!!!! I will try and get some pics when I go up next week if i remember....My uncle used to have another but it went to scrap because of the engine smoking so bad.....So he got this one from a guy in Bally Pa. Couple years ago it would make grinding noise going around turns....it eventually blew the rear, so they got another put in....Im not sure if its used or new but it was about 500 i believe he said....Great Tractor though!!!!
#35 olcowhand OFFLINE
  • 38,833 Thanks
  • 30,707 posts
Posted January 29, 2011 - 09:27 AM
Actually, they should have done the starter this time "no charge", even on parts. $200 for a rebuild when you can buy a new one for $100 or less??? Time to find a new guy for this kind of work.
#36 Nascar3244888 OFFLINE
Nascar3244888
  • 165 Thanks
  • 593 posts
Posted January 29, 2011 - 09:39 AM
Wait...you can buy one for 100.......NEW????????........WHERE!!!!!
#37 olcowhand OFFLINE
  • 38,833 Thanks
  • 30,707 posts
Posted January 29, 2011 - 09:46 AM
These are $107 & $129. I've seen them new on ebay for less than $100.
Briggs and Stratton Starter Motors 2
#38 Nascar3244888 OFFLINE
Nascar3244888
  • 165 Thanks
  • 593 posts
Posted January 29, 2011 - 10:58 AM
Holy crap I never knew that I will definitely remember that
#39 Nascar3244888 OFFLINE
Nascar3244888
  • 165 Thanks
  • 593 posts
Posted January 29, 2011 - 10:59 AM
Do they have any for the Bolens?
#40 mjodrey OFFLINE
Posted January 29, 2011 - 11:11 AM
Which engine,I see starters for Tecumseh engines on ebay quite often.
Here is one example,this one is not new.
http://cgi.ebay.com/...1#ht_500wt_1156
Edited by mjodrey, January 29, 2011 - 11:20 AM.
#41 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted January 29, 2011 - 11:15 AM
If you get the # off the starter, they have an interchange list there, also there's a contact us area if you don't see the one you need.
Daniel, thanks, that's a nice site price wise.
#42 olcowhand OFFLINE
  • 38,833 Thanks
  • 30,707 posts
Posted January 29, 2011 - 02:16 PM
Just compare your Delco number on the Bolens starter & compare to these numbers. If there's a match, it's the same starter.
DELCO 1101432, 1101863, 1101864, 1101945, 1101960, 1101970, 1101980, 1101980, 1101984, 1101992, 1101993, 1101995
  • Nascar3244888 said thank you
