Cub Transaxle Limit?
10 replies to this topic
#1 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 167 posts
Posted May 04, 2014 - 10:45 AM
Will a cub transaxle handle 100 hp? What mods will need to be done? Looking to put a kz1000 in front of it, was wondering if it will handle the hp and the rpm. The rpm will be between 8-10 grand. Thanks
#2 olcowhand ONLINE
  • 40,354 Thanks
  • 31,172 posts
Posted May 04, 2014 - 10:49 AM
No, and doubtful anything can be modded to make it handle that kind of power.
  • lesmeister said thank you
#3 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted May 04, 2014 - 11:05 AM
It might be able to handle the power but you'll have to upgrade all of the internal parts. I've been told that some of the alcohol burning pullers are making 60-80 hp.
#4 JDBrian OFFLINE
  • 9,606 Thanks
  • 14,142 posts
Posted May 04, 2014 - 04:29 PM
I'm guessing that tractors running that kind of power would use something other than the original rear end. I would check with other people running that kind of power to see what they are using.
#5 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted May 04, 2014 - 07:05 PM
You will need to up grade shafts and bearings but it will easily handle 120 HP! That's what the alcohol v twin Kohler's are making and they are putting it down through cub rears toughened up.
#6 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,421 Thanks
  • 1,855 posts
Posted May 04, 2014 - 07:18 PM
Copar Panzers could probably handle it because they had narrowed Mopar rear ends in them. They still probably would have to have been well maintained.
#7 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted May 04, 2014 - 07:53 PM
I think im right around 40hp with the diesel without any big amount of mods done. Theres a guy that pulls at my girlfriends club and I think he has an 1100cc motor and is using a cub rear but you better have some good parts in it. I would get a dart rear and go from there. A good set of gears and a over driver as well. heavy duty shifter forks along with a 4 speed unless you want reverse.
#8 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted May 05, 2014 - 01:10 PM
Yes if you build the tranny like im doing now. shafts and gears steel shift forks billet carrier. all bigger bearings and axles. Ill be posting the tranny build in a few days im waiting for a few more parts.
#9 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted May 05, 2014 - 03:15 PM
Even with the Panzer's real axle you would still need a drive train small enough and strong enough to handle that many horses.
#10 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted May 05, 2014 - 03:47 PM
Panzer axle will break. The way panzer built them they just butt welded them together.
#11 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 167 posts
Posted May 07, 2014 - 09:04 PM
That would be very helpful, I don't know anything about a cub rear end. I have heard about the dart carrier, but the rest is Greek to me. If it makes a difference, I will be pulling on dirt. I plan on using a kz1000 engine and running a straight shaft to the cub rear end. Right or wrong??? Any ideas
Edited by lesmeister, May 07, 2014 - 09:06 PM.
