Just Thinkin' What If
44 replies to this topic
#16 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted May 17, 2014 - 06:11 PM
It's also easy to laminate bend them. Eighth inch strips of wood glued together in a form.
#17 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted May 20, 2014 - 03:22 PM
The engine is lining up. I need a different pulley for the clutch; one that rides the belt on the back instead of in the Vee.
If anyone does this build, using a Wheel Horse engine would allow you to use the original PTO. You could use a WH snowblower, for one. Maybe a front mount mower.
The hard part of this build is going to be the handle bars. If you have a pipe bender-piece of cake.
I'm planning on clamping them to the axle housing.
#18 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 20, 2014 - 05:39 PM
Neat. I'll be watching to see how it turns out. Cool little project I may want to try one day.
Sent from my SAMSUNG-SGH-I437P using Tapatalk
  • LilysDad said thank you
#19 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted June 05, 2014 - 04:51 PM
The Wisconsin ABN engine had carb issues and wouldn't run. I bought a carb from SuperABen and with his advice it now purrs. :thumbs:  This is about a 4.8 HP engine, which should pull just fine.
#20 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted June 17, 2014 - 12:24 PM
I'm cleaning and painting while waiting for parts to be welded. The wood handlebars are in the mail.
I cut off the original tool box to reuse.
I wish the gray was a little darker, but this is what was available. Rims will be Wheel Horse red.
Edited by LilysDad, June 17, 2014 - 12:26 PM.
  • CRFarnsworth and New.Canadian.DB.Owner have said thanks
#21 CRFarnsworth ONLINE
CRFarnsworth
  • 4,573 Thanks
  • 2,106 posts
Posted June 17, 2014 - 05:40 PM
Just found this thread.  All i can say is COOL!     :thumbs:   Rick
#22 steve b OFFLINE
steve b
  • 119 Thanks
  • 214 posts
Posted June 18, 2014 - 01:40 PM
Looking good!
Great project.
#23 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted June 18, 2014 - 03:54 PM
I got the handle bars today. Steam bent red oak. I stained one of these. When they're dry, I'll give them a couple of coats of linseed oil mixed with spar varnish.
#24 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted June 18, 2014 - 04:51 PM
This is the original frame shortened and the original front late reattached. That plate has holes to use the Wheel Horse attachment system. That could be used to mount a WH snowblower or a custom made push plow.
  • MH81, Alc and New.Canadian.DB.Owner have said thanks
#25 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted June 19, 2014 - 08:02 PM
Looking good! Neat project! :thumbs:
Geno
#26 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted June 19, 2014 - 08:30 PM
I'm hoping this will be done in time for the Waterman Lions Club Tractor Show on July 19th. I've got a two wheel wagon it might pull.
#27 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted June 20, 2014 - 12:18 PM
These are the lower handle bar brackets. The U bolts clamp around the trans axle housings.
I am using the wooden handle bars mostly for looks. Mainly, I'm using the tractor for show. If you are making one of these to just use, I would suggest getting 1" EMT pipe and using a pipe bender to get the angle you want. That would be way cheaper and more durable in the weather.
#28 CRFarnsworth ONLINE
CRFarnsworth
  • 4,573 Thanks
  • 2,106 posts
Posted June 20, 2014 - 05:01 PM
DON'T LET UP.  Keep the pictures coming.  I'm enjoying this thread.  I'm looking forward to the end result.  Thanks.  Rick
  • MH81 and LilysDad have said thanks
#29 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted June 20, 2014 - 07:36 PM
For those of you who want to try this, the most expensive item is the handle bars($28+$15 S+H) followed by the paint. The rest of this was stuff I just have around.
#30 steve b OFFLINE
steve b
  • 119 Thanks
  • 214 posts
Posted July 01, 2014 - 12:05 PM
We need an update, how is it going?
