Just Thinkin' What If
44 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,988 Thanks
  • 9,631 posts
Posted May 04, 2014 - 08:39 AM
I have a Wheel Horse B-80 without an engine, and I'm just thinking if it would make a 2 wheeler. I could shorten the frame to move an engine back to the trans. Remove the dash stand and shorten the hood. I've got a 6 1/2 hp Briggs engine to put in it.
What I'm concerned about is the balance of the machine. What if the weight is still too far forward? And how do you park a 2 wheel tractor? How do you start and run it if there is no implement on it?
  • hamman said thank you
#2 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted May 04, 2014 - 08:46 AM
Interesting thought. I am gonna follow this and see what ideas pop up.
Geno
#3 KC9KAS ONLINE
KC9KAS
  • 5,329 Thanks
  • 4,672 posts
Posted May 04, 2014 - 09:16 AM
Wheel Horse started out as a 2 wheeled garden tractor (PONDS) and progressed to 4 wheels!
The 1 wheeled wonder Choremaster has a kick-stand to hold it up!
  • LilysDad said thank you
#4 Alc ONLINE
  • 6,750 Thanks
  • 7,399 posts
Posted May 04, 2014 - 09:38 AM
My DBs use a kick stand ,they are front heavy I don't have one but they had a 35 lb weight that you could eiher use front or rear depending on which end needed to balance the machine . Sounds like you might having a pretty neat project going . Good luck !
#5 LPBolens OFFLINE
LPBolens
  • 1,350 Thanks
  • 961 posts
Posted May 04, 2014 - 09:39 AM
Bolens Power Ho tractors have a stand that clips up under the frame when not in use, sort of like a center stand on a motorcycle. Then you don't have to have an implement on the tractor to prop it up.
  • Alc and LilysDad have said thanks
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted May 04, 2014 - 10:02 AM
All you have to do is remove the front axle:
  • jd.rasentrac, Sawdust and richwoodrocket have said thanks
#7 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,988 Thanks
  • 9,631 posts
Posted May 04, 2014 - 12:46 PM
The original 4 wheel WH had the back father than the later ones.
and add handle bars.   What is the purpose of that machine?
#8 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,988 Thanks
  • 9,631 posts
Posted May 04, 2014 - 12:47 PM
I'm also thinking that the front axle could be repurposed into a sulky.
#9 js5020 ONLINE
js5020
  • 655 Thanks
  • 766 posts
Posted May 04, 2014 - 02:24 PM
Yes Gravely had what was called a steering sulky and it is a cast iron pivoting axle just like a 4 wheel but used on the rear.  The only issue with sulkys is that you lose maneuverability and a 2 wheel can become less maneuverable than a 4 wheel.
#10 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted May 04, 2014 - 02:38 PM
Tow airplanes.
#11 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,988 Thanks
  • 9,631 posts
Posted May 07, 2014 - 03:39 PM
This is the B80 and I started to dismantle it.
This isn't the engine I'm going to use. I just set it on there to check clearance. After I reverse the gear shift and restyle the hi-lo lever, I can move the engine further back. Also, I believe I can use the original slip clutch with a different belt arraignment.
  • Alc, Cat385B and New.Canadian.DB.Owner have said thanks
#12 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,988 Thanks
  • 9,631 posts
Posted May 16, 2014 - 07:02 PM
The rain has kept me from working outside, but I worked in the shop cutting down the shift levers so that they would clear the engine. I'll post photos.
I've decided to use a Wisconsin ABN engine to power this. Also, I dug up a smaller engine pulley that will reduce the tractor speed about 20%.
I'm considering making oak handle bars in keeping with the early tractor designs. Partly because I don't have a welder and wood is easier to work. Is there any problem with this I don't know?
#13 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted May 16, 2014 - 11:23 PM
The only problem with using wood handles is if you just cut out the shape out of a board the hand grip part will crack off easy. The old school wood handles were bent or formed into the curved shape so the grain followed the contour of the handle. Not a bad idea though.
#14 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted May 17, 2014 - 12:32 AM
Very neat Idea. I will be watching to see how it goes.
#15 DougT ONLINE
DougT
    Dog Approved
  • 6,855 Thanks
  • 4,953 posts
Posted May 17, 2014 - 06:01 PM
There are several places that sell replacement plow handles. If you have someone at the local flea market or swap that deals in shovel handles and such they may have them or know where to get them. There are different widths and thicknesses. They are steamed, then bent in a jig and left to cool.
