Tea20 Ferguson Tractor 3 Point Won't Go Up Or Down ?
13 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,474 Thanks
  • 4,408 posts
Posted May 03, 2014 - 08:19 PM
Won't move up or down ?? Was working good this week with no signs of problem. Any ideas ?? Noel.
Fluid is where it should be on dip stick. 540 shaft is turning.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 03, 2014 - 08:34 PM
Is the arm you move to use the hydraulics still bolted tight where it goes into the housing?
Have the hydraulics been slow or "weak" recently?
Ben W.
#3 Rock farmer ONLINE
Rock farmer
  • 1,300 Thanks
  • 1,275 posts
Posted May 04, 2014 - 05:06 AM
Sounds like your mechanical linkage under the top cover came undone.
You can remove the side cover and look inside for something obvious.
Run it with the side cover off and look inside for leaks.
Is it up and won't go down?
Or down and won't go up?
Joe
#4 propane1 ONLINE
propane1
  • 9,474 Thanks
  • 4,408 posts
Posted May 04, 2014 - 05:43 AM
Linkage is tight. Down , won't go up. Then it sometimes goes up even with lever in down position. And with the engine running faster than idle. Then when it's on idle it goes back down slowly and doesn't matter where the handle is.
Edited by propane1, May 04, 2014 - 06:41 AM.
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,809 Thanks
  • 4,304 posts
Posted May 04, 2014 - 11:49 AM
Hello Noel, maybe this can help you - it's for the TE20. Never looked into the manual so I don't know, what's written in it...
Attached File  Massey Ferguson - Werkstatthandbuch TE20(engl.).pdf   45.11MB   81 downloads
  • propane1 said thank you
#6 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,809 Thanks
  • 4,304 posts
Posted May 04, 2014 - 11:55 AM
#7 Rock farmer ONLINE
Rock farmer
  • 1,300 Thanks
  • 1,275 posts
Posted May 07, 2014 - 06:53 PM
I'd say your going to have to take the lift cover off to figure out what's wrong.
Post back with any progress!
Joe
#8 propane1 ONLINE
propane1
  • 9,474 Thanks
  • 4,408 posts
Posted May 11, 2014 - 07:36 PM
Still working on lgt165 motor. When it's finished then will get at ferguson. To many things to do !! Thanks guys, Noel
  • jd.rasentrac and Rock farmer have said thanks
#9 propane1 ONLINE
propane1
  • 9,474 Thanks
  • 4,408 posts
Posted July 12, 2014 - 04:16 AM
Fixed the 3 point on the ferguson. Control valve was broken. Now on to the next problem. Noel
  • MH81, HowardsMF155 and Rock farmer have said thanks
#10 HowardsMF155 ONLINE
  • 2,970 Thanks
  • 3,019 posts
Posted July 12, 2014 - 07:30 AM
Glad to hear you got this fixed, I'd wondered what happened.
#11 MH81 OFFLINE
  • 29,979 Thanks
Posted July 12, 2014 - 07:39 AM
Me too.
Was it a tough fix? Any idea what happened?
#12 propane1 ONLINE
propane1
  • 9,474 Thanks
  • 4,408 posts
Posted July 13, 2014 - 07:22 AM
The stem broke in the control valve. So then it falls apart and is useless. Have to take the pump out the bottom of tractor, slide in the new control valve and put the pump back in. Not easy to work at through the side covers to hook it up to the forks.
Don't really know way it broke. New one works good but don't know for how long. If it fails soon then will have to look further in to it. Noel
  • MH81 and Rock farmer have said thanks
#13 MH81 OFFLINE
  • 29,979 Thanks
Posted November 12, 2014 - 11:37 PM
Is it still behaving?
#14 propane1 ONLINE
propane1
  • 9,474 Thanks
  • 4,408 posts
Posted November 13, 2014 - 05:11 AM
Yes , still working good. Thanks Noel
  • MH81 and Cvans have said thanks
