Ford Lgt Paint ?
23 replies to this topic
#1 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted May 02, 2014 - 10:59 PM
Hi guys i just bought a lgt 145 now its in pretty rough shape i wanted to paint it. I dont have good ventilation or air to run a spray gun but i can rattlecan it do you have any suggestion for a good paint i can spray or like the ford blue enamel engine coat would that be durable? Thanks
#2 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 02, 2014 - 11:21 PM
I've been using Tremclad Royal Blue. It's pretty close. Going by unweathered paint on my LGT145 and LT75
The Ford Blues on the shelf don't match as well.
Edited by Chopperhed, May 02, 2014 - 11:22 PM.
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 03, 2014 - 05:58 AM
If you are going to rattle can paint it take your time and use a good primer. I find a good self etching primer or a filler primer on rough areas leads to a much more durable rattle can finish. I'd also wait until you get a nice warm low humidity day to do the painting. I've gotten mixed results with rattle cans when I've rushed the job or not prepped things properly.
  • Chopperhed and TomLGT195 have said thanks
#4 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted May 03, 2014 - 07:47 AM
Ok sounds good jd chopper has that tremclad held up to minor dimgs pretty good?
#5 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 03, 2014 - 07:55 AM
As JDBrian said, a good etching primer will really increase the paint bond on steel.
Tremclad is a pretty decent paint, I've had good luck with it for the most part.
#6 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted May 03, 2014 - 09:23 AM
Canadian Tire sells a " Rust Check" brand rattle can in "Ford Equipment Blue", which is a good match to the original paint(when it was new).
  • Chopperhed said thank you
#7 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted May 03, 2014 - 04:43 PM
Ok ill try that out thanks
#8 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted May 03, 2014 - 05:39 PM
I made this steel battery cover and painted it with the Rust Check... looks pretty good from a distance...lol
#9 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted May 03, 2014 - 06:14 PM
Lance i love the muffler did u do that yourself?
#10 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted May 03, 2014 - 06:16 PM
#11 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted May 04, 2014 - 12:19 PM
The tractor had a home built stack on it when I got it, I dont care for those right in front of my face so I went to Canadian Tire and picked up some pre-bent tailpipe sections and welded them together adding them to the oem muffler. Should have been 6" longer so that it ends under the running board.. I think it would be quieter that way.
Looks like 145 spent a few years in that barn... need to get it washed up and show us some pics;)
  • stiemmy said thank you
#12 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted May 04, 2014 - 06:44 PM
Lol ya since 2007 motor was rebuilt in 2005 so hopefully it turns out good the price was right and had a tiller too
#13 TomLGT195 OFFLINE
TomLGT195
  • 4,045 Thanks
  • 2,898 posts
Posted May 05, 2014 - 05:50 PM
nice looking tractor, looks like it has a  rear pto, looks like a good wash in its future.
 I agree, prep and primer is key to getting a good rattle can finish.  warm but not hot day with low humidity too.
Good luck with the project , Tom
#14 quartermaster35 OFFLINE
quartermaster35
  • 4 Thanks
  • 7 posts
Posted May 06, 2014 - 12:00 PM
TSC (tractor supply) sells both the "old" Ford and New Holland blue paint.......... It's held up well for me.
#15 quartermaster35 OFFLINE
quartermaster35
  • 4 Thanks
  • 7 posts
Posted May 06, 2014 - 12:07 PM
I found this pic from when I painted it......
  • TomLGT195 and FilledTires have said thanks
