Time Away From The Tractors.......
6 replies to this topic
#1 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,602 Thanks
  • 2,911 posts
Posted May 02, 2014 - 08:55 PM
and such tomorrow. Need to work on the 5th wheel camper tomorrow. Water heater has a leak at the back where the water lines go into it. They are plastic and it got left on in the electric mode a year or so ago at Bear camp. It got hot enough to deform the plastic. Due to my problems last year I wasn't able to get it fixed. I believe I have a fix for it that woun't take very long but I have to remove it to do so. I also have a problem with the slideout pump not retracting the the slideout. I have called the pump company and they sent me some info on what to do without having to replace the whole unit. Will tackle that after the water heater, Wife says we can camp without having the sldeout out. I agree. I need to seal al the seams and check the rubber roof again this year. had some leaking and water damage that we got stopped last year, just want to make sure it is not leaking again this year. Put new tires on it two years ago so I think they are good to go. Sometime this year I will need to grease the wheel bearing but that woun't take long. Will need new brakes next year.   Can't complain we have owned it for 14 yrs. (second owner) and it has served us well.    Need to get this done so I can get the tractors ready for use here in a few weeks.    Thanks.
Roger.
  • tinbender7 said thank you
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted May 02, 2014 - 09:06 PM
Good luck on your repairs.
Have you ever used Sharkbite connectors?
  • hamman said thank you
#3 hamman OFFLINE
hamman
  • 6,602 Thanks
  • 2,911 posts
Posted May 02, 2014 - 09:25 PM
That is what my son said to use. I think I'm going to try them this time. Thanks.        Roger.
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted May 02, 2014 - 10:42 PM
Good clean cuts, no jagged edges inside or out... No problems anytime I've used them.
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,812 Thanks
  • 4,305 posts
Posted May 03, 2014 - 05:09 AM
you'll manage it, Roger :thumbs:
#6 shorty ONLINE
shorty
  • 5,840 Thanks
  • 5,421 posts
Posted May 03, 2014 - 05:18 AM
Those sharkbite connectors are great to use. A bit pricey tho, but so easy.
#7 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,945 Thanks
  • 6,392 posts
Posted May 03, 2014 - 10:02 AM
Seems like campers are a lot of work. My friend bought a 37 foot toy hauler camper 5th wheel and he is constantly fixing water lines and such. He does live in it awhile we are stationed in WV for work.
