Eaton 11 Seal Question
12 replies to this topic
#1 UncleWillie OFFLINE
  • 15,543 Thanks
  • 8,714 posts
Posted May 02, 2014 - 07:58 PM
I need to replace the front seal on the Buzzards hydro. The part number is 5149j, but it is a discontinued part. Does anyone have a cross reference number for it?
#2 Bolens 1000 OFFLINE
  • 14,927 Thanks
  • 18,112 posts
Posted May 02, 2014 - 08:03 PM
I should have that instock....
Which  # is it in the breakdown?
Its an 1886-01 correct?
#3 UncleWillie OFFLINE
  • 15,543 Thanks
  • 8,714 posts
Posted May 02, 2014 - 08:08 PM
It is part #3 on this diagram http://parts.sears.c...=917254830(hard to see because it is a terrible diagram). The sears part number for the eaton 11 was 3793j
Edited by UncleWillie, May 02, 2014 - 08:08 PM.
#4 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 02, 2014 - 08:13 PM
If Doc doesn't have it.  Try Googleing the part no you might be surprise on what else you will find it on.  I needed the diaphragm for the accelerator pump for a Kohler magnum.  Kohler wanted a fortune for their little kit and I didn't need the kit just the diaphragm.  I found Harley used it on one of their carburetors so I went to Harley they had in stock and it was only $15.
  • Sawdust said thank you
#5 UncleWillie OFFLINE
  • 15,543 Thanks
  • 8,714 posts
Posted May 02, 2014 - 08:19 PM
I did Google it. I haven't been able to find any specs on it.
  • HDWildBill said thank you
#6 Bolens 1000 OFFLINE
  • 14,927 Thanks
  • 18,112 posts
Posted May 02, 2014 - 08:40 PM
So... what brand of tractor is this?
Does a .375 shaft size sound right?
#7 UncleWillie OFFLINE
  • 15,543 Thanks
  • 8,714 posts
Posted May 02, 2014 - 08:48 PM
83 Sears FF. model # 917.254812. Not sure ont eh shaft size I haven't pulled it apart yet.
#8 olcowhand OFFLINE
  • 40,384 Thanks
  • 31,180 posts
Posted May 02, 2014 - 08:58 PM
I "think" this is it.  The shaft should be the same as the MTD 990 units, which is 3/4".
EATON 92999
1 / 1 Big Images
Cross Interchange Parts
Factory Number EATON 92999 CHRYSLER 1273621 CHRYSLER 1794149 CHRYSLER 231463 CHRYSLER 2438070 CHRYSLER 4032699 CHRYSLER 780541
Application & Descripition
Descripition:
Inside Diameter: 19.05 mm,0.75 in
Outside Diameter: 31.85 mm,1.254 in
Width: 6.35 mm,0.25 in
#9 olcowhand OFFLINE
  • 40,384 Thanks
  • 31,180 posts
Posted May 02, 2014 - 09:05 PM
If the above is a match, the cross is to
National Oil Seals 470954
#10 olcowhand OFFLINE
  • 40,384 Thanks
  • 31,180 posts
Posted May 02, 2014 - 09:13 PM
Also, Snapper part # 7013725YP
#11 Bolens 1000 OFFLINE
  • 14,927 Thanks
  • 18,112 posts
Posted May 02, 2014 - 09:16 PM
:ditto: I came up with the eaton 92999 as well which interchanges to National 470954
I definitely have those ones on the shelf
#12 KennyP OFFLINE
  • 37,551 Thanks
  • 45,535 posts
Posted May 03, 2014 - 04:54 AM
The FF owners manuals I uploaded show a parts breakdown for the pumps, Willie.
  • Bolens 1000 and UncleWillie have said thanks
#13 UncleWillie OFFLINE
  • 15,543 Thanks
  • 8,714 posts
Posted May 03, 2014 - 12:20 PM
I have the manual I was just too tired and sore to scan the picture last night.
