Scary Machine
26 replies to this topic
#1 HANKG OFFLINE
HANKG
  • 6,306 Thanks
  • 3,420 posts
Posted May 01, 2014 - 08:43 AM
EVER HAVE A MACHINE YOU WERE AFRAID  OF ?   MINE  WAS A ROTO  TILLER WE OWNED IN THE 1950S   WITH THE  ATTITUDE AND POWER OF GODZILLA                        KENNY P INSPIRED ME TO START THIS THREAD WITH HIS TILLER THANKS KEN FOR REMINDING ME.
  • KennyP, boyscout862 and WNYTractorTinkerer have said thanks
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted May 01, 2014 - 08:49 AM
can't remember... but I think, I always had respect, not fear, of the threshing machine
  • HANKG said thank you
#3 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted May 01, 2014 - 08:51 AM
I can tell you I Won't be running this thing!
  • boyscout862 and HANKG have said thanks
#4 farmerall OFFLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted May 01, 2014 - 09:01 AM
Did your rototiller look like this one? This one is a beast and it's just about unstoppable, it will eat rocks that would normally stall a smaller tiller.
#5 boyscout862 ONLINE
  • 12,839 Thanks
  • 9,162 posts
Posted May 01, 2014 - 09:03 AM
I'm a little afraid of all machines. My father and both grandfathers were carpenters. They all died with both eyes and all fingers intact. A little fear can be good. Its usually just your good sense trying to prevent you from doing something stupid.
My scariest machine is my chainsaw. I will not use it in slippery nor windy conditions. Good Luck, Rick
  • HDWildBill, HANKG and Bill 76 have said thanks
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 01, 2014 - 09:28 AM
I believe any machine has to be treated with respect. A momentary lapse in concentration will hurt you.
As far as the front tine tiller mentioned, I have seen much bigger and stronger men than I pull muscles and hurt themselves trying to wrestle them. They buck & and bounce and jerk you around.   However they are a manageable and very useful tool if used with the right technique.  If you let them dig a hole till the tine spindle is below the centerline then they are trying to climb out of the hole and are working against themselves and will chew up the earth and are manageable(proper adjustment of the drag is mandatry too). Provided they do not hit a rock or solid object that will lift them above the centerline of the spindle.
I prefer and own a rear tine tiller, but they too can launch themselves and be jumpy if you take too big a bite.  Taking a little bite and multiple passes are the key to running them.
  • KennyP, JDBrian, boyscout862 and 1 other said thanks
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 01, 2014 - 10:05 AM
For me the tiller is the hardest one to work on. Especially the smaller ones that use a centrifugal clutch.  Trying to set the carburetor high speed adjustment with the tine's spinning and the vibration from the engine, then having to watch the tines so they don't contact anything.  I probably need to build me some kind of adjustable jig to hold them in place to work on then like I have for the weedeaters.
I also agree with Rick, a chainsaw is the scariest piece of equipment I own and use.  Things can go south so quickly with one and you really have to stay on top of the game when you use one.
  • KennyP, boyscout862 and HANKG have said thanks
#8 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted May 01, 2014 - 10:51 AM
The scariest piece of equipment I use is my cordwood saw rig,  That has a spinning 6 inch flat belt, and a 30" open saw blade spinning just outboard of your fingers.  As others have said, my chain saw is the next scariest.
  • olcowhand, MH81, HDWildBill and 4 others have said thanks
#9 HANKG OFFLINE
HANKG
  • 6,306 Thanks
  • 3,420 posts
Posted May 01, 2014 - 10:52 AM
Yep the one  we had was front tine like I told Kenny you didn't run it ; it ran you
#10 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 01, 2014 - 11:12 AM
As a boy we had a Merry Tiller front tine and that thing would beat you silly but I was never afraid of it. Log splitters scare me. Especially if 2 people are operating one. It's too easy for a mistake to happen. Not too far from here, a few years ago, a surgeon had her hand severed while using a log splitter with her husband. Chain saws are dangerous but proper technique and protective gear take a lot of the danger out of using one. What scares me is my neighbor in his shorts and sneakers using a chain saw!
  • HDWildBill, boyscout862 and HANKG have said thanks
#11 HowardsMF155 ONLINE
  • 2,861 Thanks
  • 2,987 posts
Posted May 01, 2014 - 11:16 AM
I witnessed an open saw run with a flat belt  off a tractor being used to cut our firewood when I was young.  Scary, scary, scary sight.   Chainsaws generally get a lot of respect from me, as does my Gravely with the rotary plow and the 30 inch deck.
#12 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,313 Thanks
  • 4,949 posts
Posted May 01, 2014 - 01:32 PM
Wood chippers give me the creeps!   I haven't had much time running one and I don't want any more.  :biting_nails:
For my dad it wasn't equipment but a minibike!  Dad was convinced the Devil himself was inside that 3 horse Briggs.  :rolling:
  • JDBrian, boyscout862, HANKG and 1 other said thanks
#13 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted May 01, 2014 - 01:34 PM
Open saws like powerking 56 shows in his video are always given a lot of respect.
A 4 inch auger on a Milwaukee Howl Hog will stand you on your head if you aren't careful.
Balers, conveyors, augers, grinders all need a careful eye on the farm.
Chainsaws, handguns and wives ALL require specific care as well.
Man its a wonder any of us are still here to post ...
  • TheFarm2004, boyscout862, superaben and 2 others have said thanks
#14 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted May 01, 2014 - 03:11 PM
    Scariest machine???????  I would say it is the comatsu fork lift at work, it has three steps to get near the cab and can lift 30,000 lbs.  best part is it is a p-o-s and has no brakes!!!  That thing terrifies me, and I am only one of two people allowed to run it.
#15 grnspot110 ONLINE
grnspot110
  • 4,150 Thanks
  • 2,642 posts
Posted May 01, 2014 - 04:05 PM
Can't say that I'm "afraid" of any machine I've run, just respect them!  But, I grew up on two-cylinder tractors using PTO's without the modern spinning shields (we used the cover type shields) & grinding feed every week with a JD hammer mill using an 8" x 50' flat belt.  Hardest part with the hammer mill was the few times we used the MT, hard to line the belt up with the pulley on the back of the tractor!  Dad taught us to respect all machinery & "pay attention" to it!  ~~  Lowell
  • OldBuzzard, JDBrian and HANKG have said thanks
