Need Trans Help With Riding Mower Not A Gt But Please Help
3 replies to this topic
#1 fordman_19912000 OFFLINE
fordman_19912000
  • 25 Thanks
  • 54 posts
Posted April 30, 2014 - 07:38 PM
hey guys got a troy bilt mower for 50bucks has a kohler command 12.5 and a peerless trans the model of trans is peerless 930-023 it is stuck in one gear and the shifter wont change gears what could problem be you can feel it click into each gear shifter does shift trans but doesnt change the gear i need help please help me out thanks jason from pa
#2 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted April 30, 2014 - 07:50 PM
It probably has "shift keys" that lock the chosen gear to the shaft.  These keys often break, or wear rounded to where they won't lock in.  It's a good chance, being it's stuck in a gear that a key is broken off & lodged into that gear.   Hard to say without being there.
 They look similar to these.
  • superaben, TomLGT195 and GlenPettit have said thanks
#3 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted April 30, 2014 - 07:54 PM
Here is a parts breakdown:
Attached File  Peerless OEM Parts.pdf   301.78KB   66 downloads
PARTS PLACE
#4 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted May 01, 2014 - 08:12 AM
I would imagine the rear is like the one in my little craftsman. It somehow got moisture in it, my shifter key and collar rusted to the shaft and presented same symptoms you described. I took it apart, cleaned it all up, new grease ( should've used a heavy oil) and that was 4 yrs ago, still working fine today.
I poured water out of this one, no seals were leaking or any cracks, but full of water. You can see the shifter collar on the shaft, it got rusted and froze along with the two keys in the slots.
Edited by TAHOE, May 01, 2014 - 08:14 AM.
  • olcowhand and Gabriel have said thanks
