Need Some Info On A Lauson Vx40A Engine
10 replies to this topic
#1 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,678 Thanks
  • 1,348 posts
Posted April 30, 2014 - 07:21 PM
I've done a few searches for a Lauson VX40A engine and came up with nothing. It is on the Bolens Ridemaster mower I bought last weekend and would love to find a manual or a parts list for it. I know it's going to need a carb kit and a governor spring. From the brochure for the Ridemaster it says its a 5 1/2 hp engine.
  • trowel said thank you
#2 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted April 30, 2014 - 08:20 PM
I've got a parts list, Nate, in my old Lauson manual.
It is a 4 HP motor, 2 1/2 bore.
A lot of parts are still available for it.  Even down to rings.
The carb kit is a Walbro LMG from what I see, is that what you have?
The governor spring mounts around the air vane from what I see.  Part number 27920.  I don't have it, but I can probably lay hands on it.
I'll try to scan that parts list here in the next day or two.  I have not finished scanning that big book yet.  I did my entire Clinton literature collection, that took me almost a year for nearly 1000 pages.  I am working on the Power Products book right now.
Ben W.
  • trowel and Nato77 have said thanks
#3 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,678 Thanks
  • 1,348 posts
Posted April 30, 2014 - 11:35 PM
Here's what the carb looks like
I don't know for sure if it a Walbro or not.
Was a little surprised when I took the shroud off
Seems the mice made a little house. Now I need to see if I can get some fire out of it.
Thanks Ben
#4 jdslednut ONLINE
jdslednut
  • 675 Thanks
  • 845 posts
Posted May 01, 2014 - 12:23 AM
Nate,
I have the real deal if you want to borrow it.  The parts list as well as the "Mechanic's Handbook" dated 1961 are in my big old Tecumseh binder.
  • Nato77 and superaben have said thanks
#5 Bolens 1000 ONLINE
  • 13,635 Thanks
  • 17,578 posts
Posted May 01, 2014 - 08:27 AM
I may have the partslist if no one else can come up with one. My 8'' thick Tecumseh book may be hard to ram through the scanner :D
As Ben mentioned almost all parts are available for this engine.
The carb appears to be a clinton ( You can always tell by the little "dimples" around the edge of the carb )
Looks like its the exact one used on the Greenbrier.
Probably will need to pop the flywheel and clean the points.
  • Nato77 said thank you
#6 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,678 Thanks
  • 1,348 posts
Posted May 01, 2014 - 12:56 PM
I might have to look for a different carb because the throttle shaft is wore and has a lot of slop in it.
I should be good on the manuals. Between what Ben and Jeff come up I should find what I'm looking for.
#7 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,678 Thanks
  • 1,348 posts
Posted May 01, 2014 - 09:13 PM
Nate,
Thanks for scanning that! Now I have a bunch of reading to do.
  • jdslednut said thank you
#8 Cjallen OFFLINE
Cjallen
  • 1 posts
Posted June 12, 2014 - 12:24 AM
Nato77 I am trying to fine tune my lauson v40 engine. I need to figure out what part numbers I need for the governor spring and exactly how those springs connect and where. Do you have a diagram showing this that you can share? I also have that same carb you took a picture of its a walbro lmg 24.
Any help would be much appreciated.
Thanks
#9 DougT OFFLINE
DougT
    Dog Approved
  • 6,285 Thanks
  • 4,564 posts
Posted June 12, 2014 - 12:34 AM
Welcome to the forum. I'm sure somebody will be along that can help you. Nate checks in here often.
#10 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,678 Thanks
  • 1,348 posts
Posted June 13, 2014 - 08:38 PM
Thanks
First off welcome to the forum. Sorry I didn't see this sooner. I'll see if I can get you a copy of what I have.
#11 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Posted June 13, 2014 - 08:54 PM
Thanks
Welcome to the fourm, Nato will take care of you, Ben can also if more help is needed.
  • superaben said thank you
