Time to Enter Tractor of the Month!
Here's An Oldie For You Folks!
22 replies to this topic
#1 KennyP OFFLINE
  • 30,361 Thanks
  • 40,999 posts
Posted April 30, 2014 - 06:10 PM
Aaron's Dad dropped this off the other day. Used the fork lift attachment to bring it up so I could check it out. It has great compression! Blowed my thumb off the plug hole. Next is getting fire for the plug then carb cleaning. It's an oldie, but the tines hardly look used.
The main reason I'm fooling with this is the Clinton engine on it. It does have reverse for the tines.
  • olcowhand, Alc, Texas Deere and Horse and 10 others have said thanks
#2 olcowhand ONLINE
  • 36,471 Thanks
  • 30,058 posts
Posted April 30, 2014 - 06:12 PM
So did he give it to ya?
#3 KennyP OFFLINE
  • 30,361 Thanks
  • 40,999 posts
Posted April 30, 2014 - 06:16 PM
More or less! It's for the collective garden here, I'm just trying to see if it will run! Then I can fix whatever else pops up!
  • olcowhand said thank you
#4 KC9KAS ONLINE
KC9KAS
  • 4,960 Thanks
  • 4,394 posts
Posted April 30, 2014 - 06:24 PM
Nice.....When I first saw the tiller, I thought it looked like a SNAPPER Tiller I had back in 1974!
#5 KennyP OFFLINE
  • 30,361 Thanks
  • 40,999 posts
Posted April 30, 2014 - 06:30 PM
Think it's older with the Clinton 4.5 HP engine!
#6 LilysDad ONLINE
LilysDad
    Crazy about GTTalk
  • 10,462 Thanks
  • 8,099 posts
Posted April 30, 2014 - 06:37 PM
How hard will it be to find a gas tank?
#7 olcowhand ONLINE
  • 36,471 Thanks
  • 30,058 posts
Posted April 30, 2014 - 06:38 PM
The tines show no wear.  That engine likely has little run time on it.
#8 KennyP OFFLINE
  • 30,361 Thanks
  • 40,999 posts
Posted April 30, 2014 - 06:51 PM
Haven't a clue, but I have one I will try to use for it.
That's what I am thinking, Daniel. Aaron's Dad said it stayed parked most of the time. Got knocked over and bent the handles.
If anyone has some input on a Clinton, I could use some help here!
  • fishingbud said thank you
#9 olcowhand ONLINE
  • 36,471 Thanks
  • 30,058 posts
Posted April 30, 2014 - 06:53 PM
I think that one has the same magneto/points as used in earlier Tecumseh's.
#10 KennyP OFFLINE
  • 30,361 Thanks
  • 40,999 posts
Posted April 30, 2014 - 07:05 PM
That's a bad word to put next to a Clinton! I do not care for Tecumseh unless it's a very early model! We have another tiller here he brought over, but it has a vertical shaft Tecumseh on it! That's a last resort for me to work on!
#11 olcowhand ONLINE
  • 36,471 Thanks
  • 30,058 posts
Posted April 30, 2014 - 07:10 PM
If it's a vertical 6hp TEC, then it may be a goodun.  Some of those have pressure lubrication & last & last.  But, they still have the TEC carbs, which are almost always a pain.
#12 KennyP OFFLINE
  • 30,361 Thanks
  • 40,999 posts
Posted April 30, 2014 - 07:27 PM
Only thing I know about vertical Tec's is if you spit close by, the fuel tank has a half inch of water in it!
#13 Texas Deere and Horse OFFLINE
  • 14,468 Thanks
  • 15,392 posts
Posted April 30, 2014 - 08:58 PM
Is it an M/W tiller or is just the engine that color?
#14 bread320i OFFLINE
bread320i
  • 610 Thanks
  • 1,223 posts
Posted April 30, 2014 - 09:23 PM
Do we know if the engine is even original to the machine?
#15 KennyP OFFLINE
  • 30,361 Thanks
  • 40,999 posts
Posted May 01, 2014 - 04:47 AM
I took the reverse bracketry off to get the main belt off and it is red under there.
Looks to be. It fits the mount holes just fine.
