Cub Cadet 126 Starter Generator
6 replies to this topic
#1 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted April 28, 2014 - 11:36 PM
Hi guys found my starter/generator wasnt charging today no voltage off A looked in end cap and brushes are worn. Im up in alberta canada anyone know where i can get a new 12 volt 15 amp ccw rotation one. Or where would i bring this one to get it rebuilt? Thanks
#2 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted April 29, 2014 - 12:13 AM
I've seen brushes for sale on ebay. I picked mine up at a shop that rebuilds starters and alternators. While I was there had the commentator turned also, cost was under $50.
You should have a place up there that does electric motors and such.
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 29, 2014 - 06:44 AM
Welcome to GTTalk Karlos. Good to see another Canadian  joining us. You might try calling any local electric motor/alternator shops to see if they can fix you up.
#4 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted April 29, 2014 - 08:07 AM
Ok thanks guys i will call around today.
#5 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 29, 2014 - 02:10 PM
welcome to GTalk
#6 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted April 29, 2014 - 06:33 PM
Thanks rd jd and zippy i found a shop that will rebuild it for about 150$ i checked at napa was going to be 319$ plus shipping from cali so would be close to 400$
#7 Karlos OFFLINE
Karlos
  • 2 Thanks
  • 22 posts
Posted May 10, 2014 - 10:19 AM
So they say my generator is fine from the shop but when i put my meter from A to ground i get no reading still? On my allis i get 11.5 volts. It doesnt charge the battery either no gain even on high idle. I took apart my voltage regulator and all the points are clean and shows no sign of a short. Any help is needed guys im at a loss.
