Has Everyone Got Their Plowing Done ?
16 replies to this topic
#1 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted April 28, 2014 - 02:54 PM
With the paint barely dry on the tractor and the plow is pretty much as found condition it was time to take advantage of the nice weather and lay in a little garden.Been so long I took a GT Talk refresher course on setting up the plow. So off I went, if you thought the movie War Horse featured some brutal plowing you have have not seen my garden ! The little Briggs Model N pulled the over sized 6 x 12 tires fine thru the sod,lucky my soil is very light and sandy. Good new is the Simplicity disc and cultivator fit fine so I am in good shape that. Hopefully the weather holds and I can get back out there again and finish up. Cheers Mike
  • Alc, Texas Deere and Horse, tinbender7 and 3 others have said thanks
  • 14,803 Thanks
  • 15,497 posts
Posted April 28, 2014 - 02:56 PM
Looks like it did a nice job for you, good to see a 2 wheeler getting a workout.
  • tinbender7, farmer john and Mike Unwin have said thanks
#3 propane1 ONLINE
propane1
  • 8,722 Thanks
  • 4,129 posts
Posted April 28, 2014 - 03:59 PM
Yes all done, now I have to disk it. Still way to cold to get the ground warm enough to plant.  Nice plowing with the two wheeler. Noel
#4 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted April 28, 2014 - 04:23 PM
yeah. im just about done with my snow plowing, i hope!  that was what you were refering to wasnt it?
  • tinbender7, superaben and Mike Unwin have said thanks
#5 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted April 28, 2014 - 05:15 PM
My garden is so wet I'd lose the plow or tiller for sure.  Last of the snow piles only vanished into puddles yesterday......
Nice looking tractor, glad it got the job done for you.
  • farmer john and Mike Unwin have said thanks
#6 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted April 28, 2014 - 06:40 PM
At least someone is getting to use their machines!
Way too wet here to do anything!
#7 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted April 28, 2014 - 07:45 PM
Farmer John, that is too funny and true I sent a ignitor bracket to a shop in Manitoba to be repaired and a Webster low tension mag added and Rudy told me that a fresh inch of snow was on the ground. Really this winter just wont end,ran out of gas before I could cultivate and the monsoon season is in full swing.Other than wheel bearing grease what do you guys put on the plow after use ? I am going to try Krown a anti rust oil like Fluid Film. Cheers Mike
  • farmer john said thank you
#8 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted April 28, 2014 - 07:48 PM
"good to see a 2 wheeler getting a workout". And me too !
#9 LPBolens OFFLINE
LPBolens
  • 1,415 Thanks
  • 971 posts
Posted April 28, 2014 - 08:11 PM
I am hoping to do a little plowing this year with one of my Bolens Power Ho Deluxe tractors. But it needs to stop raining first!
#10 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted May 26, 2014 - 09:02 PM
Not sure how I missed this, but just found it searching for something else.  The tractor looks great!  love the colour scheme.  Is that the Spectramaster Green we had discussed?
#11 MH81 OFFLINE
Posted May 27, 2014 - 05:29 AM
Mike, she looks great! And a nice garden too.
  • Mike Unwin said thank you
#12 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted May 27, 2014 - 07:50 AM
The paint is a home brew mix mostly Shutter Green and Holland Yellow with a spot of Black all Armour Coat paints. Came out pretty close to the original also the Empire is done had it running on the weekend. Been a dry spring here hope you guys are getting your fair share of the rains. Take care Mike
  • MH81 and New.Canadian.DB.Owner have said thanks
#13 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted May 27, 2014 - 02:06 PM
Is one of the two upper corners of you plow support brackets welded solid?  I have two plows, one with two bolts, the other with one bolt & a weld (upper right).  Just wondering which is correct.
#14 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted May 27, 2014 - 05:50 PM
Yes one corner is welded solid, no bolt hole on that corner. Cheers Mike
#15 uisgeruithe OFFLINE
uisgeruithe
  • 2 posts
Posted May 28, 2014 - 07:52 PM
I'm still trying to find a furrow plow for my Simplicity VA, does anyon  know if other brands can fit?
