1971 Deere 110 Wiring Help
3 replies to this topic
#1 kershawa OFFLINE
kershawa
  • 1 Thanks
  • 3 posts
Posted April 28, 2014 - 12:41 PM
Can't seem to find a manual for a John Deere 110 in your manuals section, found out JD wants to make money on them still. Anyways info following:
Type: T0633
S/N 249285M
Kohler Engine
Model: K241AS
Scec: 46678d
S/N: 5071414
I am specifically looking for a wire schematic, most of the harness is still in tact but there are a couple wires (purple/white, pink, and light green), that had pulled out of different connectors and need to just find their home again. The previous owner did some repairs to the wires and doesn't look like a couple connectors are on their proper push on studs. Any information would be helpful.
Thanks.
#2 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted May 02, 2014 - 07:23 PM
Attached File  deere 110 112 electrical system.pdf   29.09KB   56 downloads
hope this helps
  • magneto1963 said thank you
#3 kershawa OFFLINE
kershawa
  • 1 Thanks
  • 3 posts
Posted May 02, 2014 - 10:41 PM
Yes that looks similar to what I need. It should get me where I need to be. Thank you.
I also have the electric mower lift that has some connections pulled from it for the same tractor. Is there someone with a diagram of that circuit?
#4 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted May 03, 2014 - 09:31 PM
this was posted a while back
I helped me with a JD 112 that had electric lift
