Gravely 12 Hp Walk Behind Tractor
5 replies to this topic
#1 minibull OFFLINE
minibull
  • 1 posts
Posted April 28, 2014 - 09:59 AM
gravely 12 hp walk behind tractor, when I engage implements they sometimes jump out of gear I have to engage the implements again.
  • 14,796 Thanks
  • 15,495 posts
Posted April 28, 2014 - 10:06 AM
Welcome to GTtalk, one of the Gravely Gurus will be along shortly to help you out. Post some photos when you get the chance.
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 28, 2014 - 01:57 PM
Possibly a simple adjustment.
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
:welcometogttalk: :wewantpics:
#5 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted April 28, 2014 - 03:51 PM
Minibull, welcome to GTTalk.
I would try two things first:
1)  Locate the PTO engagement 'knob' at the front of the transmission casting, probably under the battery, and ensure that the bolts holding the pivoting engagement lever are snug.  Loose bolts there can cause issues.
2)  The lever leading from your dash to the engagement lever there at the front of the tractor casting should rub on a crossmember along its path.  If it doesn't, do what it takes to put a bit of bend in it so it scrapes.
Those are the simple things.  Beyond that, you might need to remove the PTO 'knob' to see if your locating ball and spring are still intact, and it is possible you have a minor issue inside the transmission with the "dog gear sliding block" having escaped from captivity!  But check the simple things first, then let's move on from there.
  • CRFarnsworth said thank you
#6 js5020 OFFLINE
js5020
  • 684 Thanks
  • 787 posts
Posted April 29, 2014 - 06:01 PM
:welcometogttalk: As Howard said, check the 2 bolts retaining the shipper shaft, and the linkage for the shifter for the "simple stuff"  If all that checks out there is pin on the end of the shipper shaft that wears and then doesn't put the dog gear "over center" and causes issue.
