First Ride After 1 Year
5 replies to this topic
#1 thom OFFLINE
thom
  • 339 Thanks
  • 244 posts
Posted April 27, 2014 - 04:05 PM
Last April I posted pics of a Gilson built Lawnboy rear engine rider that I found. Yesterday I was able to ride it for the first time.lawn boy rider lf II.jpg
It was a couple of short rides  actually because the left rear tire will not stay"up". I knew the tire had gone down over the winter and figured it would be a simple matter of airing it up and riding. Not so. The tires already have tubes in them. Now the problem... I have tried to remove the wheel and tire from the axle without any success.I have tried breaking the tire loose from the wheel so I can stuff a tube in with no success either.lawn boy rider flat rear tire.jpg   I will get some penetrating oil tomorrow and begin soaking the wheel and axle I suppose. Anybody know a good method of breaking the tire from the wheel with it still on the mower? Thanks.
  • zippy1 said thank you
#2 KennyP OFFLINE
  • 38,418 Thanks
  • 45,945 posts
Posted April 27, 2014 - 04:40 PM
Sorry about the tire being short of breath! Hope you can get that figured out easily. First rides are always fun!
#3 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 27, 2014 - 05:11 PM
   How bad is the leak?  If it is not to bad try that green goop at tsc, it will usually get small leaks.  It works short term, but I would definitely try to get it off and fixed rite before the rim rots out.
   Neat looking tractor!!!
#4 thom OFFLINE
thom
  • 339 Thanks
  • 244 posts
Posted April 27, 2014 - 09:54 PM
I didn't figure any sealant or stopleak in a can would work on a tire with a tube already in it. Tubeless maybe ?
#5 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted April 27, 2014 - 11:30 PM
I don't think stop leak will work with a tube.
Is the wheel on the axle with a key way? Soak it with a "good" penetrating oil for a couple days. You may have to apply heat, I had to do that with a cub lawn tractor. Burnt up the paint, but it came off.
As for getting the tire off while on the machine. Pull the valve core and get some good tire irons and a good hammer. It has been done a time or two.
#6 thom OFFLINE
thom
  • 339 Thanks
  • 244 posts
Posted May 03, 2014 - 09:15 PM
Joy Joy. I bought two wheels and tires today and put them on a spare rear axle I had. I was able to mow my yard with the Lawnboy rider. It does great. I will now pamper it a little with an oil change and fresh air filter. I have enough parts to put together a couple more Gilsons like the Lawnboy.I think I will use all my best parts on a restoration and use the rest to make another working mower. I like them.
  • MH81 and pigsitter have said thanks
