* * * * * 1 votes
Replacing Bearings Help
8 replies to this topic
#1 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 26, 2014 - 08:48 PM
can the bearings be replaced?
it is from a Deere STX38 - black mower deck
Deere wants over $60
Amazon wants $44 shipped
the mower is my neighbor's - so I done want to take it apart to see if them can be fixed
hear it the the problem
I had to work on the motor for him and it is work great
idle the rpms are around 1250
it high speed the rpms are around 3700
you can drive it around the rpms do not drop
but turn on the mower deck and the rpms drop to around 2950
yes I did grease the spindles and the 2 idle pulleys seams okay
I had to replace the spindles, if I can just replace the bearing in the spindles
has anybody replaced the bearings in the spindle?
thanks for any help
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted April 26, 2014 - 09:00 PM
If you can get a new spindle shipped for $44, I'd say "why waste the time" and buy a new set.
If you give me a part number I might be able to beat the price.  :D
Ben W.
#3 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted April 26, 2014 - 09:20 PM
AM124511
Ben W.
#4 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,268 Thanks
  • 6,072 posts
Posted April 26, 2014 - 09:23 PM
http://www.ebay.com/...6-/261197630454
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted April 26, 2014 - 09:37 PM
AM124511
I can't beat those prices without leaving barely enough to make it worth my time to push the mouse to order it!
However, if you decide to order from your poor starving site supporter, I can do $44 plus shipping.
Ben W.
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 27, 2014 - 06:14 AM
Are you sure it's the bearings causing that much drag? Could it be a governor problem or some other issue to cause the engine to lack power?
#7 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted April 27, 2014 - 08:07 AM
$44 is a steal!
List is over $75
#8 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,268 Thanks
  • 6,072 posts
Posted April 27, 2014 - 09:23 AM
Ben W.
Sorry Ben...  I often go outside the realm of Mudder Deere to shop for parts as the machines they make are increasingly made up of other manufacturers pieces and parts..  I would order from you @ that price for sure!
Thanks for supporting this place!!
  • superaben said thank you
#9 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,268 Thanks
  • 6,072 posts
Posted April 27, 2014 - 09:24 AM
Good observation and worthy of investigation as well..
