Is It Worth Restoring?
24 replies to this topic
#1 cody6268 OFFLINE
cody6268
  • 3 Thanks
  • 9 posts
Posted April 26, 2014 - 03:36 PM
In the field, my dad and I found an old Bolens Power-Ho with cultivator. It's rusted, but only surface rust for the most part.  It appears to need at least a few parts.
The following information I got off the serial plate.
Type: 12BB01
Serial: A39498
Is it worth restoring?
Are parts difficult to find.
#2 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 26, 2014 - 03:38 PM
Hi, Welcome to GTT
The 12BB-01 Power Ho was the most produced of the power Ho line and there are still a bunch around.
They are great machines and do alot of work for their size.
You can still find some parts for the engines and chassis.
We would love to see some pictures of it!
  • 15135 Thanks
  • 15577 posts
Posted April 26, 2014 - 04:03 PM
Cody, Welcome to GTtalk. That is a great piece to restore. Please post some photos when you get the chance.
#4 cody6268 OFFLINE
cody6268
  • 3 Thanks
  • 9 posts
Posted April 26, 2014 - 04:26 PM
Got any links to places where I can find parts?
#5 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 26, 2014 - 04:28 PM
What parts are you looking for?
Did you check our site sponsors section yet?
I can supply many new parts if thats what your looking for?
#6 cody6268 OFFLINE
cody6268
  • 3 Thanks
  • 9 posts
Posted April 26, 2014 - 05:22 PM
So far I need the air cleaner for the engine, the entire implement control assembly (the handle and rod), cables (they are worn out), a few belts (cracked), and all  the rubber control handle covers, a screw or two and a tine for the cultivator attachment, as well as tires (which are $200, probably the most expensive part)
I'll probably know more tomorrow when I  take it out of the field and wash it off.
It doesn't run, and the engine's locked up.
Here's the pics of the tractor.
(Why did they use Calcium Chloride in tires back then?)
The type no. of the Briggs and Stratton engine is 702814 and the serial no. is 89645
Edited by cody6268, April 26, 2014 - 06:35 PM.
  • sacsr and Nato77 have said thanks
#7 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 26, 2014 - 05:30 PM
She's definitely seen better days but can be brought back to life.
Belts & Throttle cables are no problem to get, I have those on the shelf.
The control grips are NLA but I am working with a manufacture as we speak so stay tuned :D
The sheet metal looks great! (No cut pieces or massive dents)
Tires can be found on ebay. Are your rims still good?
Keep us updated and if you have any questions we are here to help! :thumbs:
#8 KC9KAS OFFLINE
KC9KAS
  • 5535 Thanks
  • 4770 posts
Posted April 26, 2014 - 07:43 PM
CaCl2 was used because of the weight per gallon and the fact that it wouldn't freeze.....The down side was it is corrosive.
"Beet juice"  Rim Guard is the new calcium chloride.
Oh, where are my manners... :welcometogttalk:
#9 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted April 26, 2014 - 08:40 PM
 Just put new tubes in those tires, and they'll be fine just as they are! :bigrofl:
#10 Gabriel ONLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted April 26, 2014 - 09:14 PM
WELCOME!
#11 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted April 27, 2014 - 03:22 AM
Welcome to the forum!
I've seen worst brought back to life. The key is time. Don't try and rush around trying to find parts for it.
The Briggs model 8 uses a lot of the same parts as other Briggs engines. The oil bath air cleaner housing can be swapped out for a steel one which are pretty common. The only thing with a 8R6 is if the crank is worn to much and needs replacing, finding a used one is going to be your best bet as new ones are pretty much nonexistent. The same with the goes for finding an over sized piston. There is new ones out there but they're getting scarce as no one reproduces them.
Tires and rims aren't to hard to find. A lot of different manufactures used that size of tire and rim or new ones are always an option.
The cultivator shovels were also the same as other manufactures.
  • cody6268 said thank you
#12 cody6268 OFFLINE
cody6268
  • 3 Thanks
  • 9 posts
Posted April 27, 2014 - 07:02 AM
I have an old 3HP Briggs and Stratton engine (circa mid '60s), that's missing some things, but will still run.  Are there any parts that might be interchangeable between this one and the 8R6?
#13 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted April 27, 2014 - 09:19 AM
As long it is a "8" the piston should be the same. If the carb and intake look the same they'll work. Hard to tell with out a pic of it.
#14 cody6268 OFFLINE
cody6268
  • 3 Thanks
  • 9 posts
Posted June 19, 2014 - 09:36 PM
Due to my ACT test, I've had to take a long delay.
This weekend, I plan to start work, beginning with washing it off. I will post more pics after I get all the dirt off.
#15 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted June 20, 2014 - 06:20 AM
Welcome to the forum. That would be a really cool piece to try and get running again. Maybe the engine is simply stuck fill the plug hole with marvel mystery oil and let it set for days while you are doing other things.
