Jd 110 Spark
5 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted April 25, 2014 - 07:28 PM
I just picked up a jd 110. It only sparks when I let of the key. Whats the problem?
#2 DougT OFFLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted April 25, 2014 - 07:51 PM
Bob, does this have a flywheel mag or an auto style ignition with the external coil? i'm thinking you have the wrong ignition switch for your application.
#3 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted April 25, 2014 - 08:08 PM
It has the auto style ignition with the external coil.
#4 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 25, 2014 - 08:21 PM
Faulty or incorrect ignition switch?
  • 14,730 Thanks
  • 15,470 posts
You either have the wrong switch or the contact in the switch is bad in the start position. I just had the same thing on my 4041 Simplicity.
#6 DougT OFFLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted April 25, 2014 - 08:25 PM
You need to make sure the markings on the back of your switch has an I for ignition instead of an M for magneto. Put a test light on the positive side of the coil while cranking to test for voltage.
