Monty Tractor
8 replies to this topic
#1 rolloman ONLINE
rolloman
  • 216 Thanks
  • 40 posts
Posted April 25, 2014 - 06:50 PM
Hi All here is another tractor from my collection hope you like it
  • Alc, hamman, Cvans and 4 others have said thanks
#2 HANKG ONLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted April 25, 2014 - 06:53 PM
That thing is out there very cool
#3 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 25, 2014 - 08:49 PM
   Is that home made?  or an actual tractor, I have seen small dozers but nothing like that.  Very neat and nice find
#4 KC9KAS ONLINE
KC9KAS
  • 5,331 Thanks
  • 4,674 posts
Posted April 25, 2014 - 08:53 PM
Wow, that is quite the find!
#5 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted April 26, 2014 - 01:44 AM
You don't see that everyday.
#6 MH81 OFFLINE
Posted April 26, 2014 - 05:24 AM
Nice piece. It doesn't look to be home built, but it different from any I've seen before (I've got a lot to learn :D ).
What's the background and history?
#7 KennyP ONLINE
  • 37,580 Thanks
  • 45,541 posts
Posted April 26, 2014 - 05:38 AM
That's different! Looks like a good project!
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 26, 2014 - 06:24 AM
Kewl little krawler.
#9 rolloman ONLINE
rolloman
  • 216 Thanks
  • 40 posts
Posted April 30, 2014 - 07:11 PM
Good morning guys a little update on my Monty tractor this tractor started out life as a Ransomes MG6 ITC and was used by the metropolatine water board in London and was a Lagoon scraper for removing the crust build up on sewege filter beds
There was a second tractor followed this one which had a dumper skip on the front at some point the scraper was removed from monty I think in the workshops of the waterboard and the front engine was removed and a hydraulic ram with blade fitted the engine was replaced with a Briggs and Stratton engine off 16 hp flat twin with belt driven hydraulic pump at the rear and three  point linkage frame cat 2 lift arms It has electric start amp meter hour meter and fuel cut off device too
The brake arms were also modified and a hand clutch lever fitted too.
This tractor in its present form is a one off there isnt another one like it
IF you are wondering how the engine drives from under the seat to the front if you look closely you will see a enclosed shaft which runs the full length and has twin v belt drive pullies at each end an amazing conversion and a handy workhorse
