Torque Wrench
8 replies to this topic
#1 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted April 25, 2014 - 01:28 PM
I need to replace my 1/2" drive torque wrench. I was all set to buy a Sears digital until I read the reviews. I figure I will get a 3/8" drive as well. Anybody using the Harbor Freight torque wrenches?
Edited by shallowwatersailor, April 25, 2014 - 01:40 PM.
#2 MH81 OFFLINE
Posted April 25, 2014 - 01:53 PM
I have a 3/8 and 1/2 HF wrench. They work well AS LONG as your kid doesn't unscrew them to far
  • Alc, GTTinkerer and boyscout862 have said thanks
#3 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 25, 2014 - 03:33 PM
I bet that torqued Daddy! :rolling:
  • Gtractor, MH81, Alc and 3 others have said thanks
#4 dthomp17 OFFLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted April 25, 2014 - 03:58 PM
I have a 1/2' HF torque  wrench that has worked fine for me.  I've only used it about three times.  I don't know if it matters but I always release the tension on it after I use it and before I put it away.
#5 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 25, 2014 - 04:20 PM
That is a good practice. It does matter because if you leave it with tension then the spring loose it's tension and it will not be correctly calibrated.
  • WHdbJD and boyscout862 have said thanks
#6 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted April 26, 2014 - 05:25 PM
Thanks for the replies. I had a Sears that was probably 20 years old that I ALWAYS backed off when finished. But it just wore out. I'll try the HF wrench.
#7 Sawdust ONLINE
Sawdust
  • 5,662 Thanks
  • 3,374 posts
Posted June 14, 2014 - 09:06 PM
I have an old Snap On with the dial gauge. I lost the clear plastic face on it bit still works good. I seen the HF wrenches & wondered how good they were.
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 15, 2014 - 09:16 AM
I have a couple of old Craftsman that have had a couple of issues and I have wondered about the same thing with HF ones.
#9 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted June 15, 2014 - 07:28 PM
Buy non digital, regular click style, and buy a Craftsman, or Snap On, or any other high quality branded torque wrench. Trust me, I had one of the lesser brand ones and broke it day one, right at 75 ft pounds (needed 76 and it let go right before the click).
