Photos Of The Scoop Tote And 3 Point Mounted.
32 replies to this topic
#16 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted April 27, 2014 - 01:10 PM
that looks like a real handy attachment.
  • gtcsreg and Gabriel have said thanks
#17 ENafziger OFFLINE
ENafziger
  • 261 Thanks
  • 254 posts
Posted April 28, 2014 - 09:12 AM
It works just like an endloader, down pressure and all except won't lift near as high.  It has a trip loader bucket.  It's been about 30 plus years since I've used this one but hopefully tomorrow.  Trip loader has a rope release.
How do you get down pressure with it?  My rear three points won't provide down pressure at all?
--Eric
#18 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted April 28, 2014 - 10:47 AM
Looks great on there.
  • gtcsreg said thank you
#19 gtcsreg OFFLINE
gtcsreg
  • 2149 Thanks
  • 2111 posts
Posted April 28, 2014 - 12:18 PM
--Eric
Ok, there's a stop welded in so I guess you get it when you put a partial load in the bucket.  I said that before I used it.  Memory must be going.  Sorry!
  • ENafziger said thank you
#20 ENafziger OFFLINE
ENafziger
  • 261 Thanks
  • 254 posts
Posted April 28, 2014 - 02:19 PM
No problem!!! Just making sure that mine was functioning correctly.  I do wish they did have a down pressure option on these 3 points!  The scoop looks great...
--Eric
#21 gtcsreg OFFLINE
gtcsreg
  • 2149 Thanks
  • 2111 posts
Posted April 28, 2014 - 05:58 PM
Ok, anyone else having this 3 point issue?  As you can see in the pictures, the part of the hydraulic cylinder that attaches to the top link is catching the fender pan and bending it in.  I notices that I thought this would probably happen as I put everything back together.  Nothing appeared mounted incorrectly when put together.  I know I can carefully and tastefully notch out the rear of the fender pan if needed but was wondering if I was missing something?
#22 KennyP OFFLINE
  • 50962 Thanks
  • 52632 posts
Posted April 28, 2014 - 06:17 PM
I'd be looking into the fender pan mounting. Looks way to close for me!
#23 gtcsreg OFFLINE
gtcsreg
  • 2149 Thanks
  • 2111 posts
Posted April 28, 2014 - 09:43 PM
Checked a parts diagram and confirmed it's held on by six bolts.  Can't really see any spacer or anything else that would raise the height of the fenders.  If I put in spacers they would have to be more than a quarter inch thick.  ????????  the cylinder is fairly precise in its fit with very slight give in the rubberized portion of the hydraulic hoses.  I'm stumped.
#24 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 29, 2014 - 12:57 AM
That's a strange situation. You are correct, no spacers between frame and pan.
3pt mounts look to be orientated correctly, and in the right spot.
There is only one way to mount the cylinder. I can't imagine the cylinder mount bending
or tearing away. But maybe have a look there.
Everything should be good, but that pan does look low. I have mine in the shop, I'll look
and take some pics tomorrow. Hmmm
#25 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 29, 2014 - 08:16 AM
Here's a swack of pictures. Maybe you can spot something
different from these.
  • olcowhand, KennyP and gtcsreg have said thanks
#26 gtcsreg OFFLINE
gtcsreg
  • 2149 Thanks
  • 2111 posts
Posted April 29, 2014 - 08:23 AM
Thanks Will, gone checking on my Mom this morning.  You've given me great references.
#27 KennyP OFFLINE
  • 50962 Thanks
  • 52632 posts
Posted April 29, 2014 - 08:29 AM
After looking at both sets of picks again, I wonder if just bending the pan back out may give you the clearance you need. PO may have gotten it bent somehow and it just got hooked onto the lift mechanism, bending it further.
#28 gtcsreg OFFLINE
gtcsreg
  • 2149 Thanks
  • 2111 posts
Posted April 29, 2014 - 02:01 PM
Good catch KennyP.   Bent it out and it's clearing, barely but it is clearing.  I think the cotter key got hooked on the fender and pulled it (the cotter key in the hitch pin the holds the toplink and the cylinder together).  I don't have as much clearance as Will has but I had to do a lot of hammer work to straighten the fender pan when I restored it and it's not perfect by any stretch.  Thanks to both of you!
  • IamSherwood and KennyP have said thanks
#29 KennyP OFFLINE
  • 50962 Thanks
  • 52632 posts
Posted April 29, 2014 - 03:41 PM
Glad that worked for you. Just watch what you use for a pin in there.
#30 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted April 29, 2014 - 05:42 PM
I figure people may have sat on the rear of the pan, or otherwise pulled down the rear of the pan.  You might be able to place a hardwood board under the rear edge of the fender, then using a prybar, get the pan pulled back up.
  • IamSherwood and gtcsreg have said thanks
