Ford Lgt 145 Front End Loader
ford lgt front end loader ford lgt front end loader
17 replies to this topic
#16 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted April 29, 2014 - 06:26 PM
She looks real good, nice job!
#17 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 02, 2014 - 03:48 AM
Great looking machine , and very nice job on the rebuild!! Just a word of caution tho, the front spindles are not as tough as the loader requires, and could fail under a heavy load.. This is greatly increased as the traction is increased... so be careful :thumbs:  :wave:
Thanks! I am planning on upgrading the spindles down the road a little bit to 1" thick spindles.
I have a learned quite a bit in doing this.
Some lessons I learned so far:
1. Every bolt should have a locking washer, or Loctite. If it doesn't it will shake loose!
2. My hydraulic Pump was mounted too low. It kept hitting stuff as I drove over it. I have since shortened the belt size and raised it up to give me about 6 inches of clearance from the ground.
That's it so far! Other than that, it has been awesome. I have run it every day for 2 weeks moving horse manure around, bulldozing an old garden, and leveling some dirt and it has held up easily.
Some planned upgrades are:
1. New Seat with Armrests
2. Change from Tire Chains to Ag Lug Tires
3. Add dual rear tires for stability
4. Build a Landscape Rake
5. Build a new bucket with Cutting Teeth, and pallet fork attachment
Busy, Busy!
I almost bought a Kubota BX series tractor, and I think this Garden Tractor can do almost everything I wanted to do with the BX and it has only cost me $1,500 so far vs $15,000.
If anyone has any other tips or advice, if I am missing something please feel free to let me know! This is all pretty new to me!
#18 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted May 02, 2014 - 02:54 PM
For a guy thats says "This is all pretty new to me"..... I'd say your on the track;)
the front spindles will hold up fine if you remember the GT buckets are only rated for about 400-500lbs usually.
Also tagged with one or more of these keywords: ford lgt front end loader, ford lgt, front end loader
