Wanted
Job ~*~ Sandblasting For My Cub100....ne Ohio 44084.
9 replies to this topic
#1 Gfann OFFLINE
Gfann
  • 193 Thanks
  • 226 posts
Posted April 23, 2014 - 10:56 PM
Not sure if this is the right forum or not, so mederators please do go easy on me.
I'm in NE Ohio, 44084. I'm trying to find someone to sandblast a Cub 100 for me, probably a S18 too, on separate occasions. Im will to pay of course. First on the list is the cub. I need to give it a good paint job and clean up real good. Also, paint help would be good. A source for the correct paint for the 100 would be helpful. I will probably liquid paint it, i think it will be easier to comtrol the paint that way. Ive used spray paint in the past but its difficult to control the paint and still get even coverage. Any help would be appreciated.
  • Coventry Plumber said thank you
#2 Robert Webb OFFLINE
Robert Webb
  • 878 Thanks
  • 420 posts
Posted April 24, 2014 - 04:14 AM
Look in the phone book for a commercial sand blaster.  When I had my 430 repainted, I had a local guy sand blast all of the sheet metal on my 430 and on a 318 for 150 dollars.  And that included HIM priming them as soon as he finished blasting the parts.  I supplied the primer at the recommendation of my painter.
Edited by Robert Webb, April 24, 2014 - 04:16 AM.
#3 glgrumpy OFFLINE
  • 7,548 Thanks
  • 7,173 posts
Posted April 24, 2014 - 07:08 AM
Blasting not so common anymore with regulations hurting the process. My local stripper place bakes in an oven that curls off most paints and gunk and THEN blasts to clean up in a small room inside. They used to do lots of chemical stripping too, which was good, but kinda getting away from that now, again with EPA or whomever saving the environment.  I would think you are tearing it all down to pieces and not doint as big assmebly??  I have a big 48" cabinet of my own that I can put most parts into. When I blast, I usually also do some sanding right after and prime right away or it rusts fast.  As noted, best to check papers and might try asking at shops or body supply places for suggestions in your area.
#4 panzersarebest OFFLINE
panzersarebest
  • 523 Thanks
  • 407 posts
Posted April 24, 2014 - 07:38 AM
The guy I have sand blast my stuff sandblasted a Panzer for $30.00 and a Copar Panzer for $60.00 but I dont know what he would charge for a cub cadet, depends how much paint is on it.
Chupp's Powder Coating 11402 Moreland Rd Apple Creek OH 44606 (330) 698-0558
#5 dodge trucker ONLINE
dodge trucker
  • 1,691 Thanks
  • 2,226 posts
Posted October 07, 2014 - 05:29 PM
I had a Cub Original done, the guy charged me $250 and I got it back bare, he wanted more to put it in primer.... I have done lots of my own blasting over the years and will again when I need something blasted, at that kind of prices
the only good thing about the guy that did that Original was that he called me in less than 24 hrs after I dropped it off (all in pieces) and it was done already
#6 jabelman OFFLINE
jabelman
  • 1,844 Thanks
  • 1,326 posts
Posted October 07, 2014 - 06:50 PM
I called a place by me in nj and he quoted me 350 bucks to blast a panzer! I kindly said no thanks
#7 jabelman OFFLINE
jabelman
  • 1,844 Thanks
  • 1,326 posts
#8 LilysDad OFFLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 11,183 Thanks
  • 8,517 posts
Posted October 07, 2014 - 06:58 PM
Have you considered using electrolysis?
#9 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,037 Thanks
  • 575 posts
Posted October 07, 2014 - 08:06 PM
If you consider the time it takes and the mess it makes if u blast out in the open on your own ,a few hundred dollars isn't too bad. You would have to buy and lug sand bags around and you need a pretty big compressor to get a good job. Do you have to blast the entire tractor or just the frame and rims ?
Tom
#10 Gfann OFFLINE
Gfann
  • 193 Thanks
  • 226 posts
Posted October 07, 2014 - 08:16 PM
Really just the parts I can't sand well.  The main chassis, rims, dash, grill, - I guess most of it actually. Same with the S18.
