B 112 Fuel Shutoff
7 replies to this topic
#1 steve b OFFLINE
steve b
  • 121 Thanks
  • 220 posts
Posted April 23, 2014 - 02:24 PM
Hi All,
What is the thread for the fuel shut off valve in the bottom of the B 112 gas tank? Mine is leaking and I need to replace it. I am assuming I can buy a ball valve and put a hose barb on the other side. Thanks!
  • skunkhome said thank you
#2 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted April 23, 2014 - 02:27 PM
I would just get a replacement. They have them at my local hardware store in the parts department and all I have to ask for is a metal fuel shutoff that screws into a metal tank and has a 90 degree bend in it.
  • boyscout862 and petrj6 have said thanks
#3 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 23, 2014 - 04:25 PM
   Buy another, best that way.  I believe it is a 1/8" npt thread if you still need to know.
#4 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted April 23, 2014 - 04:27 PM
Most were a universal 1/8'' NPT thread
These are the ones I carry. Most Lawn and Garden stores should stock these as well
http://www.ebay.com/...=item2337f65ae1
#5 AlleyKatz51 OFFLINE
AlleyKatz51
  • 41 Thanks
  • 35 posts
Posted April 23, 2014 - 04:42 PM
If your close to a NAPA store ask for part # SMA702351. Same thing as AC original.
#6 steve b OFFLINE
steve b
  • 121 Thanks
  • 220 posts
Posted April 24, 2014 - 07:42 AM
Thanks All!
I will give my local Napa a try! Then I will have to figure out why the carb started leaking.
#7 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted April 30, 2014 - 03:28 PM
Thanks All!
Your float may be the problem, since that may not be stopping fuel from going into the carb.
#8 steve b OFFLINE
steve b
  • 121 Thanks
  • 220 posts
Posted June 11, 2014 - 01:19 PM
Update:
NAPA had the part. 5.97. Installed it, Carb leak turned out to be a bad hose clamp at the carb. I replaced all of the fuel lines and clamps and the fuel filter while I was at it too. Running great now.
