Unknown Bolens Make Or Year...help!
15 replies to this topic
#1 Dutchie32 OFFLINE
Dutchie32
  • 4 Thanks
  • 22 posts
Posted April 22, 2014 - 10:55 AM
I have a bolens tractor that has been all painted red by previous owner and hard to find any serial number or anything to find out what it is...I thought it was maybe an 850 but the high low gear lever is located on the right side and the 850s I've seen dont have it on the right.  It has an 8hp wisconsin and I would love to know what model and approximate year it is...please help me out!
Thanks!
#2 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted April 22, 2014 - 11:29 AM
Bolens?  it says GMC right there on the hood :poke:  :poke:  :D
Seriously, I can't help.
Can you make out any of the numbers on the motor?
#3 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted April 22, 2014 - 11:33 AM
Looks like you have a transplanted 8 hp (S8-D only found in 850 and 900 models) on a 6 gear tube frame (models 1000 and above with 10 hp or larger in them).
1000, 1050, 1053, 1054, ...... All gear; 6 speed w/transaxle
1220, 1253, 1254,                  & controlled differential; built
1255 (G12) 1453 (G14)          in high/low range
800, 850, 900 ............... All gear; 3 speed w/transaxle
& controlled differential (console
mounted belt changer
lever for high/low range)
853 ........................ All gear; 3 speed w/transaxle
(console mounted belt changer
600, 650, 750, 855 (G9) ...... All gear; 3 speed w/transaxle
1055 (G10), 1155 (G11)        (manual belt change for high/
                                              low range)
Edited by MyBolens1053, April 22, 2014 - 11:38 AM.
#4 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 22, 2014 - 11:55 AM
Well, it appears you have a somewhat of a  "Frankenstein" tractor.
Assuming the steering wheel,fenders & decals are original I would say you have a 1054
The 1054 should have a 10HP TRA-10 Wisconsin engine.
  • Texas Deere and Horse, MyBolens1053 and Dutchie32 have said thanks
#5 Dutchie32 OFFLINE
Dutchie32
  • 4 Thanks
  • 22 posts
Posted April 22, 2014 - 12:26 PM
So the 1054's had the high low lever on the right side?  It has as you can see the shifter in the middle and then has parking brake and pto lever to the left and high low lever to the right.  Has the locking diff on the left wheel and the free wheel pin on the right.  So no 8hp ones had the lever on the right I guess?  Well either way it runs well!  Just wanted to know model etc for parts or whatever else I may need!
  • MyBolens1053 said thank you
#6 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 22, 2014 - 02:48 PM
From what I can tell it is mainly a 1054 with a different engine thats all.
A parts list from a 1050 or 1054 would work for you .
  • Texas Deere and Horse and MyBolens1053 have said thanks
#7 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted April 22, 2014 - 07:45 PM
Looks like you have a transplanted 8 hp (S8-D only found in 850 and 900 models) ...
The S-8D was also used in the '64 and '65 800.
#8 Dutchie32 OFFLINE
Dutchie32
  • 4 Thanks
  • 22 posts
Posted April 24, 2014 - 06:43 AM
I found the serial number under the paint on the motor and it says TRA-10D so maybe its the right motor but the motor itself has a plastic 8 on it...so still a bit confused!
Thanks guys!
#9 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 24, 2014 - 07:07 AM
Thanks guys!
There was no plastic on these engines, someone must have put a number on it.....
  • MyBolens1053 and Dutchie32 have said thanks
#10 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
Posted April 27, 2014 - 08:52 PM
Thanks guys!
So you have a 10 hp Wisconsin TRA-10D that is suppose to be on that tractor. That makes that tractor a 1054 for sure.
#11 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted April 28, 2014 - 07:54 AM
Please refresh my memory!
What were the differences between the 1970 model 1053 and the 1971 model 1054 tractors?
#12 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted April 28, 2014 - 11:51 AM
Funny what folks will do to a tractor over the span of almost 50 years.
#13 Dutchie32 OFFLINE
Dutchie32
  • 4 Thanks
  • 22 posts
Posted April 28, 2014 - 05:40 PM
Ya pretty interesting! I think it's a 1054 but no serial on the tractor and I suppose it could be a 1050 but unsure of the exact differences
#14 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted April 28, 2014 - 05:45 PM
You got a 1054 with the wrong engine like Bolens 1000 said.
#15 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 28, 2014 - 06:35 PM
Basically the only differences were years , Decals and Sheet Metal
1053 had the big "Wrap around" fenders
1054 used a different seat and "1050" style fenders with the new wood grain dash decal and Husky Dog Emblem.
I say its 90% a 1054
The engine appears original and would be correct for a 1054.
  • Bruce Dorsi and Dutchie32 have said thanks
