Rough First Time Out!
19 replies to this topic
#16 toppop52 OFFLINE
toppop52
  • 5665 Thanks
  • 4971 posts
Posted April 23, 2014 - 04:24 PM
Uh. oh.  Do you mean me?
No, two other people had it in the couple of months between you and I, I thought the guy that bought it from me was preparing to fix it.
  • ENafziger said thank you
#17 ENafziger OFFLINE
ENafziger
  • 261 Thanks
  • 254 posts
Posted April 23, 2014 - 05:08 PM
Hmm, interesting.  It may have never gotten fixed.  There is a noticeable grinding/dragging/bad sound that you can hear when shutting the tractor down...  I'll have to look into that.
#18 bigge61 OFFLINE
bigge61
  • 100 Thanks
  • 59 posts
Posted May 01, 2014 - 04:24 PM
So after many hours of trying to find the right splined shaft, with no luck what so ever!  I gave up and decided that the best course of action was to cut the bent one up and rebuild with heavier tubing.  I may have gone overboard with .25 wall DOM (1.5o.d.-1.0i.d) but I figured it would never bend again!  I ground the welds on the old shaft and pulled the splined ends out, then took them to my buddy's shop so he could turn them down on the lathe to 1.0"  Then we pressed them into the new shaft and TIG welded them on (Thanks Dave!) after I got it home I replaced the bearing at the back and both belts no more " I should have replaced that while it was out"!  Got her all put back together and it works like a charm!  When I do the next one for another 1655 that I have I will use smaller tubing, probably .125" wall DOM.  The clearance to the top of the rear end is tight and my rub a bit under operation, we shall see.
Eric
  • limebuzz and ENafziger have said thanks
#19 ENafziger OFFLINE
ENafziger
  • 261 Thanks
  • 254 posts
Posted May 01, 2014 - 04:58 PM
Beautiful job!!!
  • bigge61 said thank you
#20 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted May 01, 2014 - 07:14 PM
nice fix
