I Picked Up A D4-10 Today.
46 replies to this topic
#31 Bolens 1000 OFFLINE
  • 14,978 Thanks
  • 18,135 posts
Posted April 23, 2014 - 06:59 AM
The L63 is right for this series engine
You will be looking for a Wisconsin LQ33 or LQ39 Carb kit (Difference between the two is the LQ33 used a spring type needle and seat and the LQ39 used a solid one)
  • IamSherwood, sacsr and twostep have said thanks
#32 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted April 23, 2014 - 07:03 AM
Very clean machine! Looks like someone has already done the dirty work for you. Congrat's on the new addition.
  • IamSherwood said thank you
#33 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 23, 2014 - 07:04 AM
Thanks. How can I determine if I need the LQ33 or LQ39?
Or is there a universal kit?
#34 Bolens 1000 OFFLINE
  • 14,978 Thanks
  • 18,135 posts
Posted April 23, 2014 - 07:08 AM
It really dosen't matter which one you choose as the kits come with the needle and seat.
To check which one you have open the carb and if your needle is solid it was a LQ39 and if it has a spring on the end it was a LQ33
The genuine wisconsin is still available as well as aftermarkets. I think I have a few here on the shelf :D
  • Texas Deere and Horse and sacsr have said thanks
#35 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 23, 2014 - 07:26 AM
Thanks.
#36 olcowhand ONLINE
  • 41,004 Thanks
  • 31,371 posts
Posted April 23, 2014 - 07:30 AM
:ditto:
The TR10D was actually rated at 8.25HP and the TRA10D was something like 10.1HP if I remember correctly.
The engines are basically identical except for the connecting Rods.
:ditto:  Except for the different cranks.  The TR10D has a shorter stroke, which is why it requires a longer con rod.
  • Texas Deere and Horse, IamSherwood and sacsr have said thanks
#37 tractorman1998 OFFLINE
tractorman1998
  • 5 Thanks
  • 9 posts
Posted April 23, 2014 - 10:12 AM
nice tractor
#38 Bolens 1000 OFFLINE
  • 14,978 Thanks
  • 18,135 posts
Posted April 23, 2014 - 04:22 PM
Is that the original muffler elbow?
If it is then its the same one used on many Bolens! I thought that was a Bolens only part but I guess I was wrong!
#39 olcowhand ONLINE
  • 41,004 Thanks
  • 31,371 posts
Posted April 23, 2014 - 05:10 PM
Looks like it had the KD 540 teardrop light. You can even see the faint discolouration in the paint.
Did I see in one of your threads, that you just got one of those somewhere?
Yes, I bought a KD540 off ebay.  Around $32 with delivery.  Turned out to be NOS...never mounted!
  • Texas Deere and Horse and IamSherwood have said thanks
#40 olcowhand ONLINE
  • 41,004 Thanks
  • 31,371 posts
Posted April 23, 2014 - 05:16 PM
Yep, you wuz wong!  Stock item on Hogs, or at least some of them.  All mine but the "Rusty D4-10" have pipe fittings, but old Rusty has this manifold.
  • Bolens 1000, Texas Deere and Horse and IamSherwood have said thanks
#41 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted April 26, 2014 - 06:58 AM
BH Ser # is 8868
Wisc TRA-10D is what's in there. Spec 294765 Ser 4379199
Mine is 8896 Will, needs a lot, I'll talk to you later! Shawn
#42 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 26, 2014 - 07:25 AM
Shawn, yours probably spent a day, way back then, looking at mine as they
went down the production line together. Maybe they can meet up again at
Dan's Bush Hog reunion. :smilewink:
I had some 26 x 12 x 12 Duro's on JD rims sitting around, so I thought I'd see if they'd fit.
Just barely, but they do. I like the look. I guess they're new shoes now. Might have to get
some big Vredsteins for the front.
  • olcowhand, DH1, Titus and 3 others have said thanks
#43 KennyP OFFLINE
  • 38,172 Thanks
  • 45,835 posts
Posted April 26, 2014 - 07:58 AM
Those tires look good on there, Will!
#44 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 26, 2014 - 08:48 AM
Oh yea....! They look great on there! :thumbs:
#45 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 26, 2014 - 09:00 AM
So, you NEVER mounted it, because it's NOS?
That wouldn't bother me.
How'd you like to make 10% on your investment?
You can't get that in the banks.
:smilewink:  :rolling:  :rolling: :smilewink:
