Question About Knock And Timing?
5 replies to this topic
#1 Kentucky OFFLINE
Kentucky
  • 106 Thanks
  • 62 posts
Posted April 20, 2014 - 07:37 PM
12 hp Tecumseh..Had a knock at mid rpm's. Not noticeable at idle or high rpm's, at least not nearly as noticeable as at 1/3 throttle..Finally sputtered and died..cant get it started back. it has fire and its getting fuel..do you thinking its the timing and could possibly the knock have been from it being out of time?
#2 HDWildBill OFFLINE
  • 8,985 Thanks
Posted April 20, 2014 - 07:56 PM
Are you getting fuel to the plug?
#3 Kentucky OFFLINE
Kentucky
  • 106 Thanks
  • 62 posts
Posted April 20, 2014 - 08:16 PM
yep, getting fuel to the plug. checked it several times. its always wet..
#4 HDWildBill OFFLINE
  • 8,985 Thanks
Posted April 20, 2014 - 08:19 PM
Tried another plug?  Could be the coil is weak, breaking down or possibly the timing but that doesn't necessarily just go out unless something else happens.
#5 glgrumpy OFFLINE
  • 8,848 Thanks
  • 8,035 posts
Posted April 20, 2014 - 08:32 PM
Is this electronic solid state? They go bad and cause odd errors. Hard to parts too, but can be opened and modified to work again. Fella with online help or He builds for you.
#6 dodge trucker ONLINE
dodge trucker
  • 2,904 Thanks
  • 3,525 posts
Posted April 20, 2014 - 10:00 PM
that would be cast iron 12HP  aluminum block didn't have that setup
