Any One Got An Extra Tranny?
64 replies to this topic
#1 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted April 18, 2014 - 06:13 PM
Had the whole family and a friend in Tahoe, picked up 4 goats today, they were riding in cages in the back.
About half way home, sitting at a light, hit the gas and it all fell apart. Would barely move and had a rapid clicking noise like a baseball card in the bike spokes. Pulled in a parking lot, put in reverse.....no reverse it's gone. Figured the reverse went out but still had drive so decided to drive her home or bust. Well, shifted into 2nd and whole truck about feel apart, jerking, banging, the works!! Thankfully my uncle lived around the corner, stopped at his house and he let me park it in the front yard until I can get AAA to go get it.
My sister lives near, she took the boys home, got the friend's truck and they came back and got me and the goats.
Sooo..... now I have no Tahoe, this is time of the year I need it the most pulling the trailer. I'm thinking the Sun shell finally broke lose, common problem in the 4L60E. I know it's just not solenoids, something inside broke.
  • MH81, tinbender7, HDWildBill and 2 others have said thanks
#2 KennyP ONLINE
  • 37,487 Thanks
  • 45,503 posts
Posted April 18, 2014 - 07:29 PM
OOPS! Sorry to hear it let you down!
  • boyscout862 and TAHOE have said thanks
#3 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted April 18, 2014 - 07:45 PM
My brother had the same thing happen to him this winter. The thing that sucks for him is no one has a decently price used one around here and the truck isn't worth sticking a reman 4L60 in it.
Hope you can find a trans cheap. Its no fun being with out a truck.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 18, 2014 - 07:59 PM
That's a real bummer.  I hope you get 'er fixed up soon, otherwise you'll have to change your username!
How many miles is on that thing?
Ben W.
#5 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted April 18, 2014 - 08:20 PM
I feel for you.  Last summer, I went to pull out from a stop and there was a grinding sound.  Reverse worked, but had a 10second delay.
Put in 2nd and was able to get going and drive to a garage.
Findig a replacement was a challenge.  Mine was detroyed.  None at any of the local wreckers.  Had to get a GM factory recon.  They were on sale last August and included a 3yr/60km warrantee.
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,981 Thanks
  • 9,626 posts
Uhmmmmm. . .  but you've still got four goats to pull it with!
  • TAHOE said thank you
#7 propane1 ONLINE
propane1
  • 8,472 Thanks
  • 4,038 posts
Posted April 18, 2014 - 08:35 PM
Same problem with my s-10 chev 4x4 a few years ago. And in the trailer pulling season. My sons buddy is a transmission guy, so he fixed it. Still not good at any time, but I was on the road again within a week or so, and less money in pocket. But what do you do? Noel
#8 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted April 18, 2014 - 08:53 PM
Chevy needs to bring back the powerglide.
  • WNYTractorTinkerer and TAHOE have said thanks
#9 glgrumpy OFFLINE
  • 8,563 Thanks
  • 7,881 posts
Posted April 18, 2014 - 09:18 PM
I used to find old tranny's to put in and save money over rebuilds or servicing. Now days there are so many Letter Codes on them and you need right one to work in your system, makes it harder to find. Can't stray over so many years like in past. I would pull it and  check for a sticker with 3 letter code like 2DCA  or similar and try to match that. Think might be stamped on the plate on side near back too. The first number is the year. I just used 2 as sample, not sure what year yours was. Some are electric shifting, ratios may differ, torque convertors are diff sizes depending on size of engines, lots of stuff to look for now. I know you have at least a little money to start, heh!   Can rent trucks many places for $19.95 for the day if needed real bad.
#10 UncleWillie OFFLINE
  • 15,528 Thanks
  • 8,706 posts
Posted April 18, 2014 - 10:00 PM
You sure it is the trans and not the rear end. The clicking sounds to me like a rear broke. But I wasn't there to hear it so I will take you word for it.
#11 DougT OFFLINE
DougT
    Dog Approved
  • 6,854 Thanks
  • 4,953 posts
Posted April 18, 2014 - 10:58 PM
I think I'll lay my money on the back planetary set. That's the one being used in 1st. Usually when the sun shell breaks it doesn't make a consistant noise. It's more random and usually faint.. You lose 2nd, 4th, and rev but still have 1st and 3rd. It just results in a late shift feel and goes straight from 1st to 3rd.
  • HDWildBill, boyscout862 and TAHOE have said thanks
#12 classic ONLINE
classic
  • 5,171 Thanks
  • 2,231 posts
Posted April 18, 2014 - 11:07 PM
I went bow hunting one morning about 8 miles from home in a beat 78' GMC 1/2 ton pick up. This was like 20 years ago. The truck was 4WD and had a TH 350 short tail tranny in it. When I was done hunting, I got in the truck and it wouldn't move. All I had was reverse, so what the heck, I drove it home backwards. It sure beat walking except for the kinked neck, HA! I had a rebuilt TH 350 long tail trans with a cracked case. My friends mom backed into the trans while it was on the garage floor, and that's how the case got cracked, so he gave it to me for parts.
Anyway, I couldn't find a cheap short tail trans for the truck, so I put both transmissions side by side and disassembled them. The clutch packs were smoked in the short tail trans, so I just put the guts from the long tail in it. I never had a transmission apart and I didn't have a manual. Somehow I got it all back together and torqued all of the bolts down to " I hope it stays together " specs. I put the trans back in the truck, started it up, prayed to God, then put it in drive. Son of a ..... it works! I drove the truck for 6 months and my brother ended up driving it to Colorado from NY. He needed a truck since he was moving out there, and he traded me his 69 Olds Cutlass convertible for it. He drove the truck in Colorado until he traded it in on another vehicle.
  • sacsr, boyscout862 and TAHOE have said thanks
#13 olcowhand ONLINE
  • 40,365 Thanks
  • 31,175 posts
Posted April 19, 2014 - 07:25 AM
Yes, bring back the TH350!  So many auto parts could be standardized, but then the designers wouldn't be happy.  Sorry for your issues Marty.
#14 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted April 19, 2014 - 08:21 PM
Ben W.
140K, won't be changing my screen name. Can't afford to fix it, but even less able to afford a different one.
4 baby goats don't pull much
No need for a rental, I have the Firebird which is my daily driver anyway.
Oh yea, it's definitely the tranny. It pulled okay in 1st, but nothing else.
Everything I've read points to sun shell. The clicking is the splines stripping on the sun shell shaft. I'm not sure if I have third, when it tried to shift, I thought the truck was going to explode, wouldn't shift and jerked, banged and clanged!
My BIL use to rebuilds, gonna ask him tomorrow if he still does them, should get it done for under hopefully $400, but I want upgraded sun shell and at least a rebuild convertor too. If he doesn't, my neighbor has a good friend who does it for a living, he's gonna get me a price.
I followed the roll back driver to the house after he picked up Tahoe from my uncle's, when we got there he said he talked to the owner
 ( his dad) of their junkyard, they happened to have a '98 or 99 Tahoe with bad motor, he said they would sell me the tranny for $350.
Sounds great, but if it's only a couple hundred more a complete rebuild of mine, may go that route just for a piece of mind.
Good old powerglide, my neighbor has two of them, doubt either of his '79 Malibu drag cars would miss them  :smilewink:  :D
  • GTTinkerer said thank you
#15 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,643 Thanks
  • 5,839 posts
Posted April 19, 2014 - 08:30 PM
Junkyard transmissions usually turn out to be a waste of time. At least for me...
  • GTTinkerer and TAHOE have said thanks
