Sleeve Hitch The Trailer Ball Adapter
5 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted April 18, 2014 - 11:47 AM
figured id post a few pics on what i built to tow a trailer with my 110 or pull trees or pull anything without taking the hitch off.  ANd as most know when you put a ball on the normal hitch its usually way to low to do anything
  • DH1, hamman, johndeereelfman and 7 others have said thanks
#2 UncleWillie ONLINE
  • 15,676 Thanks
  • 8,763 posts
Posted April 18, 2014 - 12:10 PM
Nice setup. When I got the GTV18 it had a rigged up ball that just slipped thru the hitch with no way to attach it. If you went over a hill or put too much on the back of the trailer it would come off.
  • superspeedex said thank you
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted April 18, 2014 - 12:19 PM
Yea kinda a good thing though too like if you had not enough toung weight and went down a hill but i use mine just to move trailers and stuff around
#4 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted April 18, 2014 - 02:45 PM
Nice fab work. I like your trailer in the 1st photo.
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 18, 2014 - 03:05 PM
Nice fab job on the hitch ball holder!! The no down pressure issue could bite you on a sleeve hitch when the load shifts off of the tongue. The way around this would be to set it up so that the hitch is all the way up  when you are using the ball. You could make some other arrangement to adjust hitch ball height if needed.  It is at a better height than the tractors rear hitch bracket for anything bigger than a garden cart.
  • tinbender7 and superspeedex have said thanks
#6 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted April 18, 2014 - 03:42 PM
my hitch is the hole way up
