John Deere 200 Series Weight Bracket
11 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted April 17, 2014 - 10:08 PM
So i got a 210 a while back and it had a few attachments one was this front weight its factory john deere the shipping label says 1983 on it its has 1 slab weight probably 40lbs buddy has more weight hed sell me.  Im pretty big into deere and have never seen one of these nor can i find them on the internet does anyone know what it is worth they would work on the closed frame 300 series too.  So what are these worth are they rare??
#2 jd.rasentrac ONLINE
jd.rasentrac
  • 4,750 Thanks
  • 4,244 posts
Posted April 18, 2014 - 12:47 AM
Seems to be original
and that is the first weight, that I see. If they are in stock, your JD dealer can say, what they cost.
Edit: here in D you pay one Euro (~1.,25 $) per 1 kg (2.2 lbs) - for the weight - but herefore you can get more money.
The worth of the braket is: ??? 20 $ ???. Best will be, you ask a dealer.
Edited by jd.rasentrac, April 18, 2014 - 12:57 AM.
  • superspeedex said thank you
#3 JDBrian OFFLINE
  • 9,611 Thanks
  • 14,144 posts
Posted April 18, 2014 - 04:45 AM
I  think the newer tractors use the suitcase style weights. I've never seen that style of weight up here on a 200 or 300 series tractor. I've seen it on a 110.
  • jd.rasentrac and superspeedex have said thanks
#4 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted April 18, 2014 - 05:47 AM
The weight bracket resells on ebay every now and then between $75.00 - $125.00. As for the weight itself, they are getting harder to find, but are out there. I've seen then resell anywhere from $50.00 each to $150.00 each. Your weight and bracket are original. The weight brackets are now being reproduced, and one of our sponsors, Hapco, sells them. The weights were being reproduced at one time, but I don't think they are anymore. I think the only difference between the original weights and the reproduction weights were the JD stamp. The new reproduction weights didn't have them.
Nice score, and will come in handy if you use rear mounted equipment such as the garden plow or rototiller. If your buddy has more weights like this to sell than what you need, let me know. I'm still looking to find/buy two more of these weights for my personal collection.
Edited by johndeereelfman, April 18, 2014 - 05:50 AM.
  • tractorgarden, jd.rasentrac and superspeedex have said thanks
#5 Littledeere ONLINE
Littledeere
  • 1,649 Thanks
  • 1,481 posts
Posted April 18, 2014 - 06:25 AM
Troy the aftermarket weights have the JD part number on them they are jusy a little lighter stamped
Edited by Littledeere, April 18, 2014 - 06:26 AM.
  • tractorgarden and johndeereelfman have said thanks
#6 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted April 18, 2014 - 11:25 AM
Yea thats what i thought i never seen them its a real nice factory option though id like to buy the adapter to make it fit my 110
#7 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted April 18, 2014 - 12:45 PM
The mounting brackets to make the weight fit you round fender are available through Hapco as well. I believe they are around $35.00 for the set of two. They also carry the rear frame hanger brackets, so that you can mount the weight to the rear of your round fender. You will still need the main front weight brackets though in order to use them on the rear.
#8 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted April 18, 2014 - 01:41 PM
ill have to look them up
#9 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted May 17, 2014 - 07:43 AM
The mount "should" work on a 120/140/300 series as the mount on the 43 blade from the 100/200 series will mount up fine on the 120/140/300 series tractor.  Nice find!
#10 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted May 17, 2014 - 05:47 PM
yea i need to get an adapeter to go from 110 style to 210 probaly make one once i have the time
#11 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted May 18, 2014 - 10:17 AM
As Travis stated above, the weight bracket you have will fit all flat fender 110/112, 120/140, 200 series and 300 series tractors. If you are looking to mount this weight bracket to the front of your round fender tractor, it can work by finding and using the adapter bracket as shown below:
#12 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted May 18, 2014 - 08:19 PM
Yea i have seen them ill make one someday
