Allis Chalmers 816 Puller
3 replies to this topic
#1 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 172 posts
Posted April 14, 2014 - 12:10 PM
Has anyone used a allis chalmers 816 to make a puller? Are they strong enough, what are the weak points, any information would be great. Thanks
#2 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,449 Thanks
  • 1,869 posts
Posted April 14, 2014 - 02:42 PM
There wa an 800 series puller on CL a while back and I believe they said the axle broke but not totally sure but I do know that something on it had broke. Hope this helps some in your decision.
  • lesmeister said thank you
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted April 14, 2014 - 05:35 PM
I would say no. The axles look weak on these and with them having a vari drive? it would cause the belt to really slip and put a lot of strain on the trans. There are ways to make the belts not slip but I would be afraid of the axles going crunch. So I would say no. Look for an actual gear drive. Something with a horizontal motor in it. That's just my opinion though
#4 Cheetah OFFLINE
Cheetah
  • 57 Thanks
  • 57 posts
Posted May 28, 2014 - 11:51 PM
Depends on the class.
Here in NH, we have what we call an 8" Superstock class, which means you must use 8" wheels with a maximum of 18x9.50x8 tires in which the tires can be cut to improve traction. It is a lightweight class, with 750 lbs (with driver) being the max. The rules for the class also requires the tractors to be belt drive, and they must run a Briggs motor with a max of 18 hp.
I ran a Simplicity 6216 which is the same tractor AFAIK, just a different paint job, for a few years. I was the season champ for 3 straight years, then I gave it to my dad, and last year he was the season champ.
So yes, it can be a good puller, but it depends on the class you plan to run in. If you plan to run it in a 1000 lb, stock class, it may not be the ideal choice with 12" wheels. It depends on the club's rules that you intend to pull with.
