Newbie Working On A Newer 1886-01 Husky Large Frame
26 replies to this topic
#1 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted April 13, 2014 - 11:31 AM
Hi all.........Got a great deal on a 1886-01 husky. Got her to start up after changing the battery, checking all fluids, came with a 33" tiller. Here's the kicker......The bendix type starter does not engage the fly wheel. So i used a screwdriver to push it in and hold it there while cranking, it runs. I pulled the engine hoping to repair the starter, but the kit i ordered seems way too small to fit the starter shaft. Sooo i am looking for a starter bendix repair kit. the starter is mounted by 3 bolts to the oilpan, thru an opening. All the manuals i checked had the 'L' shaped mounting bracket on the starter. I am starting to think someone changed out the starter?, or no? Its a Kohler K482s-35113b engine sn#3018425. Thinking the tractor is an 1886-01 by some details....pull out choke, pull out throttle with lock, cannot find sn# sticker for tractor. Also the tractor is Blue in color. maybe someone can help me figure this out..............
Thanks,
Bernie
  • Dieselcubmike said thank you
#2 KennyP ONLINE
  • 53135 Thanks
  • 53295 posts
Posted April 13, 2014 - 11:37 AM
:wave: Welcome to the forum! Folks will be along with help. Got any pics of the tractor?
  • bprzyw said thank you
#3 Oldford OFFLINE
Oldford
  • 1135 Thanks
  • 786 posts
Posted April 13, 2014 - 11:57 AM
Either it's not spinning fast enough to raise the gear, or the gear is sticking.  Does it engage with the plug removed?  If not make sure you are getting strong current to the starter like with jumpers off a car battery.  If not try oil the bendix on the shaft maybe it's stuck.  If that doesn't work could be weak or hanging brushes.  Remove starter take apart have a look.  Brushes under $20 just need to know make of starter prestolite, bosch etc, brushes easy to install.  just start with the simple stuff one step at a time good luck
#4 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted April 13, 2014 - 12:45 PM
Sounds like you have ordered a newer kit the early K482s had a different starter.
#5 boyscout862 ONLINE
  • 15259 Thanks
  • 10022 posts
Posted April 13, 2014 - 02:08 PM
Welcome to GTT. You have a great tractor. Download the manuals from our Manuals Section if you need it. We would like to see pics so that we can admire your treasure. Good Luck, Rick
#6 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted April 13, 2014 - 02:38 PM
Thanks everyone. Its a very good tractor, not that i know, only had it a week, but it does run fine. Pics to follow.....OldFord, removed the starter, hooked up to a battery charger 12v 50amp setting, she sure spins good, just does not kick out the gear. Took it apart (just the bendix), cleaned and oiled it up, smooth action. Still does not kick the gear out. Now how to post pics..................
#7 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted April 13, 2014 - 02:47 PM
Ok, posted pics to gallery.......
#8 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted April 13, 2014 - 02:58 PM
  • Dieselcubmike and bprzyw have said thanks
#9 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted April 13, 2014 - 05:00 PM
I say thats a 1886-01.
#10 Dieselcubmike OFFLINE
Dieselcubmike
  • 1345 Thanks
  • 1529 posts
Posted April 13, 2014 - 08:02 PM
Hello and welcome :wave:
#11 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Worst case,look in the ph book for someone that rebuilds starters and alternators,I have a plac e near me that does them, if there not toast he charges approx. $70.00 to rebuild them,
#12 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted April 14, 2014 - 06:47 AM
Yep, going to do that today, find some where and give em a call. There are several local. Can I get a close year for the tractor/engine? I am thinking 1971.
#13 NJKen OFFLINE
NJKen
  • 1362 Thanks
  • 1284 posts
Posted April 14, 2014 - 07:49 AM
Yes, 1971 if it's a 1886-01
#14 MYMF10 OFFLINE
MYMF10
  • 161 Thanks
  • 83 posts
Posted April 14, 2014 - 07:56 AM
Welcome to GTTalk!!
Sent from my HUAWEI H881C using Tapatalk
#15 bprzyw OFFLINE
bprzyw
  • 268 Thanks
  • 256 posts
Posted April 14, 2014 - 09:40 AM
Took starter to local Heilig repair, there was lots of mmm's and oh's, and whats it from, year.... Hopefully they can do it. I left it there, as they could not give me a direct answer. Crossing fingers now.
Oh, and anyone got the blue paint code?
